Thoughts on new Direzza star spec 265-40-17
255 looks stupid on the stock 8" wheel, so no sense trying to fit a 265 on there. 245 fits PERFECTLY on the 8" wheel, I don't know why people think that extra 10mm of tread and extra sidewall flex will be so much better.
It really depends what you are looking to do. With a 245 you can run either a 40 or 45 sidewall. Both have there ups and downs. I am still not set with with what I am going to get however I think I would prefer the shorter sidewall. It should help turn in response at the cost of a couple mph.
Bringing this tread back from the dead. So can anyone provide insight into a 17x9.5 wheel that will fit a 265/40/17 tire and not rub or require fender rolling? It seems like 17x9 rota dpt with 255/40/17 is about as wide as you can go without having to roll fenders.
255s weight 28lbs and dots are at 19 so 47lbs or I could run 245/40 on stock bbs and I'm looking at 44lbs but the width is way different. 255s have 10.4 inched and 245s have 9.8 more than half an inch at four corners
TheMasongtre
11
Mar 22, 2023 04:01 AM
04Evo851374
13
Mar 29, 2014 02:03 PM
