Pulsating/Shaking after coilover+rim/tire install
So, a couple weeks ago i put in Stance GR+Pro Coilovers and 17x9.5 rota p45r's with 255/40/17 z1 StarSpecs, and in first and second at low RPMs it when i give it gas theres a pulsating/shaking when accelerating. The things that pop into my hear are.
A- Clutch is slipping because of wide, bigger tires
B- Axle is slipping
Can anyone help me out?
I really hope its not my transmission
B- Axle is slipping
Not sure on those spacers but did you extend your wheel studs? Not sure if those are good spacers or not but cheapo ones might not set properly hub centric or lug centric etc. Someone else can go into details but I am not up to snuff with that. I remember my Galant the wheels were lug centric so they needed to be tightened perfectly or they would wobble.
Lugs torqued properly
Tires balance properly?
I really don't think it is a clutch since you would rev with out going anywhere, axles would click more than wobble before it snaps and you would know if it snaps.
I really think it has to do with the wheel/tires more than anything else.
Try swapping the stockers back on and see if that changes anything. Best place to start.
Hmm this only happens on accel in low gears....this is usually a problem with drive axles or prop shafts...Does the steering wheel shake? If so your prob. is most likely in the front, whether it be axles, tires, etc. May be a dumb question but are the tires balanced properly? I have also seen separated tread on a tire cause this same issue...the tires are new i'm assuming, but it wouldn't be the first time I've seen defective tires right out of the gate.
I could always bring it somewhere to make sure theyre balanced properly, although i watched the the guy do it.
What do you mean seperated tread? yes the tires are brand new.
I don't think it's the axles, I mean there are a TON of members running your set up and more aggressive and I've never seen a thread on pulsations and vibrations after the install. Maybe it's the alignment?
shvc1991
23
Feb 16, 2015 05:16 AM
Minnesota MR
24
Dec 1, 2009 08:39 PM
