Different Tires
Different Tires
I just purchased an Evo a few weeks ago with a thought to be broken transmission. Once the car was torn apart it was discovered that the output shaft going from the transmission to the transfer case had rounded off the splines that it slides into so the shaft was just spinning. The car is back on the road now but I noticed there is three different tires on the car. The front two are Goodyear Eagle LS-2's and one rear is a Fuzion ZRi and the other is a Fuzion HRi. I measured all four tires and the left front and left rear are exactly the same circumference. The right rear is about 1/2 an inch different then the left side tires and the right front is about an 1/8th difference then the left side tires. Would this be a large enough difference in tire size to do damage to the transfer case? Opinions on if a new set of matching tires is needed? Thanks
first off let me apologize to you because that's like giving a special olympics kid two different brand shoe in two different size - hooray for the previous owner.
but yes in all seriousness please invest in a cheap set of matching tires for the time being should you have to; whether or not it contributed to the failure of the output shaft that's a tough call since the difference in UTQG is 60 - but even then that's another topic of debate since you're also dealing with driving habits. with that in mind, provided below are links via tirerack w/info for your current tires, you be the judge, but that's a serious kluge of WTFs
Goodyear Eagle LS-2's - "Luxury Sport Grand Touring All Season tires "
http://www.tirerack.com/tires/tires....del=Eagle+LS-2
Fuzion ZRi - "Ultra High Performance Summer tire"
http://www.tirerack.com/tires/tires....&tireModel=ZRi
Fuzion HRi - "High Performance All-Season tire "
http://www.tirerack.com/tires/tires....&tireModel=HRi
to the previous owner of your evo: REALLY!!??
billybond_09
Aug 3, 2015 11:10 AM
deludedbuzz
For Sale - Cars For Sale
Jan 12, 2014 03:46 PM
St1g
42
Aug 30, 2012 05:08 AM
DallasN2O
28
Feb 10, 2009 11:42 AM
