Camber plate question
Old Apr 18, 2010 | 05:46 PM
frycztech's Avatar
I have a set of robispec kw v3's i was wondering if i should do camber plates? What ones should i do? Will the plates raise my car?
Old Apr 18, 2010 | 06:02 PM
Laxman's Avatar
Watch out for what plates you get because there is not a whole lot of thread on the top of KWs.
I have the KSport plates for Camber and Caster, but I had to get them machined to fit properly. Vorshlag Plates work, and so will the yet to be released GT Worx plates fit without problems.
Best bet is to call Robi.
Old Apr 18, 2010 | 06:12 PM
frycztech's Avatar
Is it worth getting camber plates? are there any others i should look at?
Old Apr 19, 2010 | 12:22 AM
robi's Avatar
Camber plates will give you more camber and caster adjustment. The V3s with the stock bolts maxed out get you plenty of camber for street driving, but more caster is always a good thing.
Our favourites are vorshlags, which are beautifully made, and K-macs, which offer more adjustment but aren't quite as fancy as the vorshlags.
There are plenty of other good options out there as well, but it comes down to what you need as far as the alignment goes.
-Peter@robispec
Old Apr 19, 2010 | 04:27 AM
frycztech's Avatar
Thanks for the help robi. I do auto x from time to time but i do like to go threw tight back roads lol do u think i should do camber plates?
Old Apr 19, 2010 | 04:45 PM
robi's Avatar
replied to your pm.
