Grateful...
Grateful...
Ok, so i purchased an 06 ix se about a month ago with 22k miles and drove it for 2k miles more until we noticed grinding on the rear. This was unfortuanatly due to rear pads being worn. So I had it put on a lift to change the rotors and noticed that on the inner part of the tire near the suspension, BOTH front tires were shreded/grinded down to "white thread" The tires might just blow at any momment.
Im trying to figure out what might have caused the tires to tare up. Has anyone had problems like this before? When the car was purchased, it already came on a NEGATIVE camber with 225/35r18 90w tires. Suspension is Megan coilovers.
Could it be that the tires are too wide/big for the car?
A common Megan Coilover problem?
Nevertheless, since the day I saw those tires... i have been nothing but grateful...Lucky to be alive. I had been driving/racing unaware...
I've seen worst cambers than this. The previous owner may have just cambered them in to tuck the tire and prevent fender rub but that will o ly bring me 2 my question if these size tires are appropriate for the body. I will buy new tires and camber them back out. I will let you guys know how that goes.
From your tire wear, stupid tire size and coilovers, I'm going out on a limb that your car is "hellaflush", br0. In other words, it has wheels and tires that don't really fit the car but look sick y0. See "wrong fitment crew" stupidity in Show & Shine or Member's Gallery on NASIOC. Cambered to 'tuck' is exactly what I'm talking about.
You also listed 225/35r18 tires. What size (width) rims is the car running? On anything larger than an 18x8 wheel, those tires are going to be seriously stretched, which won't help wear either.
l8r)
Just an update. The camber was fine. the tires that were torn from the front were swapped with the rears. And there is no damage being done to the fronts. I came to the conclusion that these tires were already damaged before the coilovers were installed... hense the coilovers being purchased. Any questions please just ask.
