Choosing a tire size for 18x9 +36
Just ordered a set of Enkei PF01's in 18x9 +35 (obvious typo in the title)
I'll be going with Direzza's, but I'm just deciding on size.
I can roll my rear fenders, that's no problem, my car isn't all that low on Robispec V3's, however, the car sees daily street duty, some weekend auto-x and occasional road racing.
so, 255/35 or 40 or should I be stepping up to a 265?
Thanks, and since I haven't seen any pics of this wheel on an Evo, I'll be sure to update.
No "Guru" help has arrived=)
Im running the X wheel 18x8.5 (+38) & run a Toyo 255/35 ( No rear roll & on C/o's squatted deep in rear)....A 40 series side wall looks great but could be a tight fit both up front & in the rear IMO.....Your +35 offset is a great choice. You could probably get away w/ a 265/35 w/ a rear roll.
My suspension was tuned by an EVO "Pro" & only recommends the higher offset wheels +34 or higher. He will remove your rear strut & ensure the tire will float into the well w/out contact. (Fender roll, fender pull & cambers adjusted from there)
Havent you found any other members running the Enkei PF01's?
Good Luck!!! Peace
Good Luck!!! Peace
Good Luck!!! Peace
Good Luck!!! Peace
IMO the best fit on an 18x9 for street use is a 265/35 - it's what I run on my 18x9s. Pretty much the identical diameter to stock, looks great, but does require rolling of rear fenders.
l8r)
l8r)
