KW v3 install question
so i will be receiving my Kw's in tomarow and i was told that since these wont be coming wiht the camber bolt i would have to use my stock ones, BUT my question is how do i make them work. I was told by SE that all i had to do is grind em down? now i tried Searching here and on the local forum and wasnt able to find anything. any one able to help me out here? thanks
My KWs look like they'll take the top stock eccentric bolt. The bottom bolt is not eccentric and the stock one should work.
Try calling up KW at 1-800-445-3767 and ask them to send you a pair of the eccentric bolts. I called them a while back inquiring on spring rates and they were pretty helpful.
