wheel spacers BAD or OK!!
Is it bad to run them on all for. The rim's I just got hit the brakes up front but they have a 40mm off set and the stock one are 38mm off set. It look like I would need a 10mm to 15mm spacer.
As long as you get a good quality spacer, it should be fine. I've run a 5mm spacer up front for a couple of years w/out issues and I know others have raced on larger spacers than that.
l8r)
l8r)
What brand and model are the wheels? Sounds like you need closer to a 20-25mm. Many people don't like them, for whatever reason. I ran 20mm spacers for a long time. Get something that is hubcentric, like the Ichiba brand that Touge Factory sells. Bolt-on spacers are fine. Slip-on with extended lugnuts are even better.
I cant for the life of me find an extended lug kit. Can somebody post a link?
Ninja Edit: http://www.maperformance.com/arp-sub...-stud-kit.html
I've used them on my VW before and so have a lot of other VW owners. It will eventually wear out your wheel bearings but just make sure you have hubcentric spacers and it will save you a lot of trouble.
FS[Northeast]: wheels spacers 20mm and 25mm
dtmevox
Feb 11, 2016 05:19 AM
BaD2RaSS
14
Apr 29, 2010 12:28 PM
icedomin8r
Aug 1, 2007 11:13 AM
evo ippo
May 5, 2007 09:22 PM
