all 4 tires losing pressure
I got my evo in July with all 4 tires set at 35 psi. They held steady at 35 throughout the summer. Now the vicious northern california winter dropped the temperature down to around 65/40 and the tire pressure dropped to about 32psi for all 4 tires a few weeks ago and 31-30 today...
Is this just a result of temperature change or do I have a 4 bent rims/4 nails in tires
thanks!
PS. All measurements taken with cold tires.
thanks!
Just a suggestion....the manufacturer's recommended inflation pressure is posted on a sticker in the driver's door jamb:
Front = 32psi
Rear = 29psi
Now this can be discussed to death depending on what you need out of your car. But, for daily driving and stock performance on handling, these pressures are recomended by Mitsubishi.
Front = 32psi
Rear = 29psi
Front = 32psi
Rear = 29psi
Front = 32psi
Rear = 29psi
I did my tire rotation yesterday and found that both rear tires had nails in them. That's what probably caused the tire pressure loss. Check your tires if you get the chance.
Ouch, sorry about your rears.
I just went out and checked the tires, holding steady at 30-31psi. With ambient temperture holding steady for the last week, I guess the weather was the cause after all.
DGlory
May 18, 2011 02:43 PM
Srt-4 Turbo 7
Jul 30, 2007 06:26 AM
