A-046 vs. A-048 Advans?
What is the difference between A-046 and A-048 Advans? I believe that my EVO came with A-046's stock. Are A-048's a better tire? What should I replace the stockers with? I know the stock A-046's can be expensive. Is there a replacement that works as well and is cheaper. Opinions...?
Thanks for the info. Are replacement A-046's available presently and do you have any idea how much I would expect to pay to replace them vs. the Dunlop Star Specs mentioned? The reason I as is I have a set of the original A-046's from my '05 EVO that have been sitting in storage and I was considering using them on my '06 instead of buying new tires. I'm presently running an 18" combo so I could just switch back to my stock wheels. I'm not sure how long tires last in storage. I would rather use them then have them go bad.
OK, I guess I should substantiate. ![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
My opinion for the "best" street tire on the market, that is the closest to an R-compound, and performs very well on the track, is the RE-11. Doesn't overheat like the Dunlops, and has stiffer sidewalls and better feel than the Yokohamas.
Of course, that's just my opinion. Should have specified that before.
92gsxbaltimore
Apr 16, 2011 11:38 PM
BoostLover99
20
Jun 1, 2008 06:19 AM
Kica
49
Mar 28, 2006 08:50 PM
