Brake pad rubbing
Brake pad rubbing
Heres the problem, i installed evo 8 brembos on my eclipse. direct bolt on. When i corner though you can hear the pad rubbing on the rotor, is there something i may have missed or is this a common problem? Normally there are clips that hold the pad up against the piston but i did not see any on these. Just shims in between the pad an pistons. Are these entirely free floating then? If so how do i stop pad rubbing? Thanks
the middle black spring insert? yes. pistons seem to be equal. i will tear them apart when i go to change the rear pads and figure it out. I figured there would be clips that would the pads against the pistons as many brakes do.
Spring insert? Can you post a pic of the calipers on the car?
Hi Im Vinh
26
Mar 1, 2012 08:20 AM
army.engineer
Jan 30, 2011 10:48 PM
weneversleep
Apr 15, 2010 09:46 AM
s2000
Aug 21, 2006 09:53 PM
