my tires melted at the track
i just came home from my first track day with my evo and the inside on my passanger front tire seems to have gotem melted. is this normal? the other 3 tires are fine
suspension is stock
tires are dunlop z1's 235/45/17 at 34psi coild tire pressor
suspension is stock
Yeah, it looks like the tire got over-worked. Also, it looks like it can use a lot more camber! It's a bit disturbing to have that much uneven wear across the tire.
This is my tire wear on my left side tires from my S2000, running Buttonwillow CW13 with high air temp of the day hitting 97F. So it was a hot day.
Bridgestone Potenza RE-11s in 245/40/17. Take into account my alignment was more optimal as you can see my wear is pretty much flat across the tires. And the S2k is about 400lbs lighter than the Evo 8/9. You can see that the outboard shoulders did get worked pretty hard going in the clock-wise direction, but no wear issues at all, no feathering, etc.
I did use the Star Specs in 245/40/17 back when I had my Evo 8 and I was not a fan. I only tracked them in cold weather, so no comparison to your conditions, but I did not like their feel at all.
Stock alignment, stock suspension, power of car, track, driver experience is what did that to the tires.
