New brake pads installed, few concerns
Hey guys, I recently installed a set of CL brakes RC5+ on the front and rear of my car. This was my first time swapping pads, and there are a few things that make me wonder if I did the swap correctly:
1. Even when I'm not pressing the brake pedal, at least 1 of the pads appears to rub very slightly against the rotor. Sometimes when I'm pulling away from a stop/red light, I'll hear one of the pads squeaking a bit, yet I'm not braking. Also, when I'm driving next to a concrete wall or barrier, I can hear the scrapping of the pad on the rotor. The pad might just be "leaning" on the rotor, because I can still push the car when it's in neutral and I don't really see a difference in resistance.
2. The first time that I brake when going in a new direction (ie. switching from forward to reverse), I can hear a bit of clunking, like if the pads are moving around. It only does it the first time, after that they're fine.
Is there anything specific I should check? I plan to go lapping on Sat., should I reinstall the pads to make sure they're on correctly before then, or will they stop rubbing as the pad material wears down?
Cheers!
Cheers!
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
I would just make sure the pins and the clips are properly installed... ie.. pins in all the way, not loose or baking out and make sure the clips are underneath the pins on each side. If everything appears to be secure I think you'll be ok.
Bedding procedure as follows, 4-5 quick slow downs from 60-20mph in a row (stomp them HARD, but don't come to a complete stop). Then use the brakes as little as possible till they can completely cool.
Good Luck, happy lapping.
Most disc brakes have no device to pull the pads away from the rotor when not braking. What ever run out the rotor has is supposed to be enough to knock the pads back. This doesn't mean that the pads won't rub a little on a high spot on the rotor. This is normal. And, if the brakes want to be noisy, you may hear it.
Bringing this thread back up...How much rubbing is too much? I can hear a faint squeak coming from my brakes at low speed. It isn't very loud but enough to be a little annoying. It goes away when the brakes are applied. The brakes were bedded and copper anti-seize was used on the back of the pads. Is there any way to minimize the amount of dragging? Could new shims be helpful? The pads are DS2500's BTW.
ambystom01
12
Jan 14, 2006 09:52 AM
KK
59
Dec 16, 2005 05:15 PM
x838nwy
Nov 29, 2005 10:21 PM
