Bottoming Out
Old Sep 11, 2010 | 12:55 AM
shimmi's Avatar
Question Bottoming Out
I have a 2005 evo 8 that just got lowered 1 inch with Megan Racing springs and now if i have more than 2 people in the car the rear tires rub. Any suggestions besides raising it back up? It has stock suspension besides the springs so that could be part of the problem. any suggestions on what shocks/struts i should get? not coilovers (out of price range)
Old Sep 11, 2010 | 01:46 AM
sideway180sx's Avatar
maybe you should try a different spring one that is stiffer then what you have? with maybe bilstein shocks?
Old Sep 11, 2010 | 08:36 AM
cfdfireman1's Avatar
What size tires? You could add some camber back there.
Old Sep 11, 2010 | 01:14 PM
shimmi's Avatar
255/35/18
Old Sep 11, 2010 | 01:17 PM
Jp7's Avatar
Jp7
Thats a silly comment.
Springs provide a force that is basically linear with displacement
Shocks provide a force that is basically linear with velocity
Why would changing the damping force make any difference here.
Old Sep 11, 2010 | 02:22 PM
Where do the tires rub? Quarter panel lip or somewhere else? You may need to roll the metal, add or subtract some camber depending on where it's rubbing.
Old Sep 11, 2010 | 02:28 PM
shimmi's Avatar
I am not sure i believe they are rubbing on the lip
Old Sep 11, 2010 | 05:15 PM
more camber or a little roll then. do you know what your alignment specs are?
Old Sep 11, 2010 | 07:06 PM
JohnDoe1984's Avatar
Swift springs don't drop the rear as much as some others.
Tire rub is the issue really, not the springs. Even if you took the weight out and went back to stock springs your tires would still rub when the rear bottoms out.
Just mess with spacers, fender rolling, and adjusting camber to keep the tires from rubbing.
Old Sep 11, 2010 | 07:27 PM
Smike's Avatar
I thought they stopped making those springs. They were uber low front and rear -2 front and -1.9 rear. That is a lot of rear lowering.
Routes: add rear camber, negative is tire wear and handling. Change tire size, cost is tires. Change springs to a different set, cost of springs and alignment.
Old Sep 11, 2010 | 07:45 PM
n2oiroc's Avatar
my rear tires rubbed. then i got new struts and no more rubbing! you sure yours are good?
Old Sep 11, 2010 | 07:55 PM
bbyevo8u's Avatar
maybe getting your fenders rolled that might help?
Old Sep 11, 2010 | 08:26 PM
fabcas311's Avatar
roll the fenders
Viet-Speed
Jan 30, 2016 12:51 AM
nickolime
Sep 1, 2015 09:19 AM
SteezerAlec323
Jul 26, 2015 05:17 PM
L888Apex
38
Jul 30, 2012 08:23 AM
jman85
Apr 22, 2011 10:57 PM
