Which BBK?
#31
I researched a bit more on the Stoptech Trophy kit and it has a lot of R&D into it to increase caliper stiffness, weight reduction, and rotor cooling. The cost isn't that bad either really when you consider what it is that you are getting. It's looking like I will be going with the Stoptech Trophy kit.
#33
Thanks, they are a pretty stout setup with a lot of nice qualities. From what I read, Stoptech did testing on the venting of the center had and came to the conclusion that the majority of the cooling came from the backside and not the front side, making venting from the front a moot point.
#36
If you want the most retarded brake setup ever, contact these guys http://www.mooresport.com/ and ask them about their 6 piston Alcon caliper with matching custom hub setup for Evolutions. Be prepared to drop about $10k and that is just for the front setup.
Dan
Dan
#38
#41
Now, of course I could go with a Brembo monoblock setup or stoptech ceramic brake setup, but I just don't need that much brake. I'm also favoring Stoptech because they are local, about 40 miles away. My main thrust behind purchasing the new brake setup is to have enough brakes to handle back to back highspeed braking in an event such as the texas mile or similar. I won't be tracking the car competitively in any way other then that to be honest.
Are you affiliated with a brake company Chris? If so, feel free to PM me with any comparable systems that you have or experience with different setups.
http://www.stoptech.com/tech_info/wp_monobloc.shtml
http://www.stasisengineering.com/whi...te%20paper.pdf
#43
Here is a pic. of the RB Competition 13" Front Rotor and 4 Piston Caliper installed on the 06 MR. This kit is designed for those who have 17" wheels. http://i297.photobucket.com/albums/m...s/IMG_6433.jpg MPG
#44
We didn't forget the REAR 13" 4 Piston Caliper for the 17" wheels http://i297.photobucket.com/albums/m...s/IMG_6432.jpg MPG
#45
There was not alot left to work with using the 17" wheels.. http://i297.photobucket.com/albums/m...s/IMG_6424.jpg MPG
