How To Clean Leftover Adhesive From Wheel Weights
Another great way to go is this... I have one, I removed all the pinstripes off my M3, and also did it on an old chevy truck/tow vehicle. It is amazing if you have never seen it used.. I would do this for the quick removal of residue on the inside of a wheel from wheel weights..
Eraser Wheel:
![](http://image.sporttruck.com/f/14476341+w750+st0/0609st_10_z+toyota_tacoma+eraser_wheel.jpg)
Eraser Wheel:
![](http://freshstartdetail.com/main/wp-content/uploads/2010/01/decal-removal-step-2.jpg)
Goo Gone is the best I've used. It still requires lots of elbow grease and is a PITA.
If the inside of your wheel is not painted you can use something more abrasive such as gas.
I have seen Grainger sells a "Wheel Weight Adhesive Removal Tool", It's a red plastic piece. Haven't seen it in use before, though.
we have them at work...its basically a plastic wedge with a handle..
it does nothing to remove the adhesive..since its plastic and just bends and ive had them just not even be able to get under the weights because the normal driving heating of the bakes/wheels bonds the weights so much to the wheel...
i hate sticky weights but they make the wheels look so much better than when weights are clamed on the edge..
phishy
Evo X How Tos / Installations
30
Feb 21, 2016 01:33 AM
