real quick question
they will fit on your wheels but your wheels might not fit in your fenderwell with a tire that tall. you also do not want to run just 2 snows or different tires at all for that matter if that was the plan.
They will fit, but you really should be replacing all four at once. The tread needs to be the same and the life of all four tires should be similar or you will prematurely wear out your differentials..
http://www.tirerack.com/tires/tirete....jsp?techid=18
225/55/17 can fit for winter use. Might rub.
Must have 4 tires. Not 2.
