Installing bump steer kit, what else while i am there?
Like the title says, i am putting in a whiteline front bumpsteer kit and was wondering what are some other fairly easy things to replace while i have my front suspension apart. I was thinking the Perrin Anti Lift Kit (PSRS) but that might be a bit more labor intensive (Anyone know labor cost for this btw?).
Can anyone recommend some bushings to replace that are in the neighborhood that are not labor intensive?
https://www.evolutionm.net/forums/ev...t-carnage.html
PS I assume you mean roll center correction kit. The bump steer goes in the rear.
Damn, i must be confused. From the description of "bump steer" i thought it was the front wheels that are effected by it the most (loosing traction when hitting imperfections in the road and thus pushing straight instead of turning).
But i am sure i want to get rid of that because i can feel how the car wants to push straight (understeer) when i make a hard turn on a crappy surface.
So if its the back then i might want to do a rear swaybar, i am just afraid of snap overseer. I heard a stiff aftermarket bar might cause this.
Basically i want the car to keep that natural OEM balance where its easy for newbs to control.
Learn the car stock first. Then worry about handling upgrades. FWIW, a lot of guys run the stock rear bar. You don't have to get a huge one anyways. Numerous adjustable bars out there. Do some searching.
