Adjustment bolts!
Old Dec 28, 2010, 10:08 PM
a4rontran's Avatar
Adjustment bolts!
Hi,
I went to have my car alignment few days ago. The mechanic said that the adjustment bolts on evo 8 are weak. He suggested to get better bolts. Would please tell me where can i get these bolts?
Thanks
Old Dec 28, 2010, 10:36 PM
sscottttt's Avatar
The factory bolts that allow for camber adjustment are much stronger than any aftermarket "camber bolts". If someone swapped out the stock bolts for aftermarket in an attempt to gain more camber then your mechanic may be right. If the original bolts are still in place then you have no reason to worry.
Old Dec 29, 2010, 05:11 AM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Please take a picture of one and/or of the lower strut mount (2 bolts to the hub).
Old Dec 29, 2010, 08:39 AM
Solo II Evo's Avatar
Did you buy your car used? Real factory Evo 8 suspension bolts are incredibly strong - as are the forged aluminum parts they bolt to. It's possible the last owner put on some Home Depot bolts to replace the real ones, in which case your car isn't safe to drive (at all).
Old Dec 29, 2010, 11:19 AM
a4rontran's Avatar
Yeah I bought the car used. The mechanic did the alignment is well known for his work in SoCa here. I don't know if you guys hear about West End Alignment. His name is Darin. He told me that the design of the evo 8-9 bolts are not a good as the Evo X ones because It can be worn out easier than the Evo X bolt pattern. He just suggested me to get the new ones ready, when I decide to get alignment again. So he can swap the bolts in.
Thanks
Old Dec 29, 2010, 12:21 PM
donour's Avatar
Which bolts are you talking about? The front bolts are very strong. The rear ones tend to strip if you hit them with an impact gun. Torque spec on those is only like 65 ft.lb.
d
Old Dec 29, 2010, 12:24 PM
n2oiroc's Avatar
must be talking about the rear eccentric bolts.
Old Dec 29, 2010, 01:55 PM
a4rontran's Avatar
Yeah, the rear ones. I'm sorry for not clarifying it. Do you guys know where can I get better one?
Old Dec 29, 2010, 02:02 PM
n2oiroc's Avatar
the dealer. the problem isnt that they are bad bolts, they just get worn and weak from repeated over tightening. here are the part #'s. you need 2 of each.
Old Dec 29, 2010, 02:46 PM
a4rontran's Avatar
^^^ those are the ones that I'm talking about. Do they have after market ones? I'm trying to find a better build than the stock ones.
Old Dec 29, 2010, 02:53 PM
Smike's Avatar
Stock are more than adequate.
Old Dec 29, 2010, 03:28 PM
n2oiroc's Avatar
Old Dec 29, 2010, 03:30 PM
n2oiroc's Avatar
stock are the only option and will hold up fine. most alignment guys over torque them so they dont slip. just like any other bolt if its over torqued too many times it will break. just buy new oem ones every few alignments.
Old Dec 29, 2010, 04:42 PM
cfdfireman1's Avatar
adequate maybe
but they suck, make sure they use plenty of antiseize and a torque wrench on them. Good idea to have some spares on hand anytime you touch these bolts.
Old Dec 29, 2010, 04:48 PM
Sirnixalot's Avatar
+1 for antiseize! My evo is much older than all of yours and my rear stock bolts were rusted to the inner sleve on the bushings in the rear for both camber and toe.
Quick Reply: Adjustment bolts!
