UnderBody Brace
If you autocross then leave the stock bars as they are unless you like running in prepared.
Also, I don't really see how people are "Noticing" a difference unless you have at a minimum urethane bushings. Those will have far more compliance than changing the stock bars can help.
Doesn't mean that bar wont have an effect without the bushing though. Depends on the angles with which everything flexes. Looking at how the chassis braces are mounted, it should help maintain more negative camber, probably compensating a bit for the squishy rubber bushings.
i am not looking for the WOW effect, i just figured since the car is in the air and i had to lossen up the stock braces to drop the dp, i figured i would swap them for something more rigid. The aftermarket braces have very little flex due to the fact the brace is connected on all four corners, so the energy is transferred equal, isntead of just from one side to another on the oem ones.
My recommendation in chassis bracing is the RS trunk bar and Carbing 6-point Lower Arm Bar. I had those plus a cheap $23 eBay rear strut tower brace on my IX and it really tightened things up on the autocross course.
https://www.evolutionm.net/forums/se...r-arm-bar.html
https://www.evolutionm.net/forums/se...trunk-bar.html
DKC6691
Northwest Region
Feb 25, 2012 06:49 PM
