Carbone Lorraine RC5+ - Pictures & Review
Install Notes & Initial Impressions
Justin and I got these installed in about an hour and half. This included dealing with several stubborn lug nuts, jacking the car up, as well as cleaning up the rotors and calipers. I sanded down the flat outer edges of the rotors where the rust accumulates to smooth it out and get any loose debris off. I did this to all my rotor while Justin slipped the pads into the calipers. On the rear rotors I also cleaned up the rear inside portion where the e-brake clamps on. I did this to get rid of any loose debris and give it a cleaner surface. I didn't go crazy digging into the metal. I just cleared the surface. I should have taken photos of the dust/crumble pile I had after I was done with all 4 rotors. It was pretty bad. I also sprayed down the calipers with windex and afterward quick detailer to get all the salt, road grime and brake dust off them. They still need much TLC. Hopefully I'll be able to send them to TCC sooner than later.
After the install, I pumped the brakes a whole bunch of times to get the pressure back in the lines and get the pedal feel back. It was pretty loose before I did this. Right off the bat, I noticed that I had brake feel and grip from the pads immediately after backing out of the driveway to stop the car and get into gear. I was pretty damn surprised. Coming to my first stop, I had normal brake grip right away. No delay, no slack, just straight up grip. Is this due to the layer of pad already on my rotors? Possibly. I'm not sure how these pads would react on brand new rotors. Maybe there would have been some delay that we're normally used to when installing brand new brakes. The pads do make some noise, but it's nothing annoying, at least not to me. I want brakes that will stop. Knowing I have race pads on the car, I don't care if they made a tad bit of noise. I know my car will stop, and stop damn well for that matter.
That's all I have for now since I still need to take a week of easy daily driving to let the pads scrub the rotors. I felt a little bit of shudder when slowing down on the highway at highway speeds. Not hard braking, just normal braking. It seemed to go away when I applied more/greater pressure. I'll be able to comment more on this tomorrow since I drive 30 miles round trip to and from work on pretty much 85% highway. So far I am very pleased.
Photos have been added to the OP!
-Jalal
-Jalal
For Street use and track use, the RC5+ has worked very well for us.
No need to swap back and forth from street to race pads.
This is of course if you are using standard high performance street tires.
Great review Jalal!
and great pictures too!
Great review Jalal!
-Jalal
I have been running these for around 8 months now - so far so good. They are noisy however, at least for me. I even pulled em and reapplied a bunch of paste to the back, didnt help to much.
That said, i used em on VIR - got up to around 135-140 and then would be stomping on the brakes. Never had any fade, or issues of any sort. Now i drive around daily, and they're still fine.
Edit: I also picked mine up from togue, but thats not to important.
-Jalal
-Jalal
Also, could you define "noisy"? I.e., is it braaaaaaake .... squeak . stop -- or - brake . squeeeeeeaaaaaaak . stop
I used to run HP+ pads on my car, and I loved the initial bite of the pad, but my car sounded like a freight train stopping.
The OEM shims have always helped me a lot in quieting down a pad.
l8r)
l8r)
l8r)
l8r)
The more and more miles I put on them, the more and more I'll be able to comment.
Remember, I still need to really bed these pads. This will happen next week and I'll let everyone know how they are after that!
-Jalal
I'm still running my OEM shims - and its mostly under light braking that i get squeal. Think the last 15 feet before the light, where you're barely slowing from coasting.
I have to stop alot at guardpost to get on-base, and they squeal at those guys. From speed i dont have noise, until i get to threshold level force, then its just noise from the pads on rotors, not squeal.
Towards the end of the stop it's like Race Brake squeeeeeeaaak. It def gets loud. I don't mind it.
-Jalal
-Jalal
