Tire / Wheel Fitment Questions
#1668
#1670
Hey guys, I'm sure this has been brought up in the thread but I can't seem to find it.
I'm about to drop the money on Rota Grids 18x9.5 +20
I have Falken 425s - 245/40s
I am also getting 5mm spacers for the front.
Will I have any problems running 245/40s? I know I will need to roll the front/rears flat and may have to pull the rear a bit. I plan on lowering the car quite a bit...
Please let me know what you guys think.
Mikey
Mikey
#1672
XXR 522 17 x 9 +25 question
Hello guys and gals,
I'm wondering if any of you evo guys have ran the XXR 522 that are 17x9 w/ offset +25? I'm not sure if it'll clear the brembos. I've searched and could not find anyone who have ran this size before. Any help or input is appreciated.
#1675
Hey guys,
I want to make sure this set up will fit my car without any fender rolling/modifications. I am currently running an EVO IX with bilsteins and swift springs and am interested in the following set up:
Rims 18x9 +30
Tires 225/40/18
2x 5mm spacers for the front
Any help would be appreciated, thanks!
Rims 18x9 +30
Tires 225/40/18
#1676
Hey guys,
Rims 18x9 +30
Tires 225/40/18
Rims 18x9 +30
Tires 225/40/18
#1677
RPF1 18x9.5 +38
I'm looking to order these rims very very soon. Originally I wanted to run RPF1's with a +15 offset at all corners. I know that spacers are not required with this offset. I have been reading lately that some people feel that they stick out too far. I dont want to have "that" look.
Now Im thinking about running RPF1 18x9.5 +38 WITH 20mm spacers at all four corners. I know spacers are required in the front with this offset and not required in the rear with this offset. The only reason why Im thinking I need the spacers in the rear is because I dont want the front sticking out further than the rears. This should put me at +18 at each corner.
Sidenote, I have already purchased 255/35/18's and I have coilovers on the car. Thanks in advance.
#1678
We have a set of those in stock for $320 ea if interested. A 20mm spacer will leave you with an 18mm offset. There is also an 18x9.5 with a 15mm offset we have that may eliminate the need for spacers all together. It's only a 3mm diff but some think that's too much for their taste. Those are the same cost.
