Tire / Wheel Fitment Questions
Old Mar 11, 2012, 09:18 AM
  #1876
JWB_EVO_9's Avatar
Ok so I have a question about Fitment....... Yay!
Now I'm about to buy a set of 17x9 +22 gramlight 57D's, now I'm guessing someone has asked this question before but I'm over researching and need to know cause I really want these wheels. I know the fronts are fine it's just the rears I'm worried about, they have already been roiled to clear the 17x8.5 +30 TE37's that are on there cause I run 255/40/17 federal RSR. Apperantly because they are a round wall tire they count as a 265 when it comes to Fitment and they use to scrub, I run -3.0 camber up front and -1.5 rear.
Old Mar 19, 2012, 10:19 PM
  #1877
pedalhead_267's Avatar
Hey,
I'm thinking about putting MSR 043's on my 2006 ralliart... It's lowered on tien's and the rims are a +35 offset 17x7.5 . most likely just be sticking to a 205/40/17 tire.. maybe a 215 if that will work?
Im wondering if i will have enough clearance or will i have to do some fender mods?
Let me know what u think!
Thanks
Old Mar 21, 2012, 07:36 PM
  #1878
ineedboostman's Avatar
I'm looking into getting konig milligrams. 18 by 8.5. What offset do I want to run on my evo8? Think the options are 25, 35, 45. I want to get the wheels as close to flush as possible would I need spacers?
Old Mar 25, 2012, 01:46 PM
  #1879
vstone48's Avatar
Hey guys, im thinking about getting a square set up of work meisters s1 3p in 18x9.5 + 23,24, or 29 (not too sure). Not sure of the modification that would be needed, and if the stock brembos would fit. I also forgot to mention that this will be a daily driver, it will never see the track, and will ride on stock blistens and on swift spec r springs.
Now i did try to look for the answer but the ones i found weren't in the sizes i wanted or were to radical for for : https://www.evolutionm.net/forums/ev...ml#post9643490 (post 5985) and http://www.rimtuck.com/setup/view/783
Thanks for your time
Old Mar 28, 2012, 06:50 AM
  #1880
nikkadanny's Avatar
couldnt do a quick search since im about to go in for work but has anyone ran a 18x10.5 wheel on stock body?
Old Mar 28, 2012, 07:27 AM
  #1881
chu
chu's Avatar
Have seen 18x10 on stock body with rolled fenders. However, the car has Stoptech brakes front and rear, which changed the spacing quite a bit, which allowed the owner to run that size.
Old Apr 2, 2012, 08:56 PM
  #1882
DagYo369's Avatar
I got a set of volks 18x8.5 39 offset I do believe hard to read with new coating but they sit flush with qtr's without tires.
which brings me to my question if I run a 255/35 tire will it hang over rim at all or be flush? Trying to decide on if I should do 245/35 or 255/35 or maybe even a 245/40 just wondering if anyone has had this setup thanks for any help! ps sorry im not going to read through 100 pages to see. i tried search and couldnt find anything.
Old Apr 6, 2012, 05:23 AM
  #1883
eric06ix's Avatar
Should have posted this here first instead of a new thread
I have a set of 17x8.5 30 offset RPF1s that I want to run a 255-40 tire and I'm looking at a set of the GTWorx springs with MR Bilsteins. Will the rears rub with that wide of a tire, slightly lowered? I have neither parts on the car now, and I wanted to check before I bought tires and springs.
Old Apr 6, 2012, 06:14 PM
  #1884
DagYo369's Avatar
bump for my exact same question ive been poundering! im 39 offset though and wanna do 35 tall. i put my wheels on my car and they basically line up with qtr panels so you cant tuck them i doubt. but really wanna hear peoples experience!
Old Apr 7, 2012, 11:49 AM
  #1885
savagejay1's Avatar
Currently on Stock wheels (evo 8) and snow tires. Really need to pull the snows off so I'm looking at new wheels and tires. Does anyone know if WEDSSPORT TC105N 17x9 +35 with Dunlop Z1 245/40 will fit on stock suspension with no spacers, no rubbing and no fender rolling/pulling?
New to buying wheels and tires so I've done a lot of research but couldn't find anything about someone running this exact setup.
Thanks
Old Apr 9, 2012, 01:09 PM
  #1886
S3CR3T's Avatar
So I have owned my evo for about 8 months now if not more. When I bought the evo it already had 19x10 wheels on it. They rub when doing full turns as in as far as you can turn it. Also I think there is the possibility I'm losing a couple of inches on how far they will turn. You can here the power steering staring when i have it firmly turned all the way. When it comes to wheels I know literally nothing I have heard of wheel spacers etc can anyone give me a detailed way I could possibly fix this without having to buy new wheels.
Old Apr 10, 2012, 06:40 AM
  #1887
jayg4u's Avatar
Take off the Wheel and look to see what size spacer they alread have on it...maybe they just have the wrong size.
Old Apr 10, 2012, 09:43 AM
  #1888
vboy720's Avatar
Can i fit 18x9.5+22 in the rear without rubbing? Rear is rolled and has -2.0 camber, tires are 266/35. Or should i do 18x9.5+30?
Old Apr 12, 2012, 10:14 AM
  #1889
ca18hatch24's Avatar
Ok, so I am tired of searching....
I would like to run the rpf1's in either 17x9 or 17x9.5, with a 255/40/17 star spec or Hankook rs-3. Suspension will be Bilstein HD's on swift spec-r's. I have read that the 17x9 +38 offset will work with a 20mm spacer up front, which will allow me to still rotate tires, which is important. Can anyone confirm this? Also, what offset/spacers work with the 17x9.5's? I don't want to have to do too much body work to make them fit....maybe a light roll.
Old Apr 13, 2012, 12:22 PM
  #1890
Jschlo4's Avatar
Uber Noob here, know nothing about tire sizes, offsets, spacers or anything relevant to wheels and tires.
I love the Enkei rajin...I want to make sure that the 18x8.5 will fit with a 235/40r/18 tire on it. I have the MR bilstein and Swift spring set up. Will I need to roll the fenders if I go with this setup, will it even fit? Do i need spacers? HELP!
Thanks
Quick Reply: Tire / Wheel Fitment Questions
