Tire / Wheel Fitment Questions
Old Nov 2, 2012, 01:54 PM
  #2011
Canadian-Ix's Avatar
I can get 17x9.75 +20 or 17x8.25 +35, will one of these wheels work on evo ix without fender rolling? Thanks again, im trying to learn offsets
Old Nov 2, 2012, 02:04 PM
  #2012
chu
chu's Avatar
The 17x8.5 +35s will work without rolling fenders.
Old Nov 2, 2012, 02:31 PM
  #2013
Thank you very much for taking the time to help me out, much appreciated man! Cheers!
Old Nov 2, 2012, 04:28 PM
  #2014
xtruemassacre's Avatar
Originally Posted by rabbit61319
EVO 8 with big 4 piston caliper with 225/45/17, no spacer.
Enkei RPF1 17", anyone can help with spec?
Thank you!!
you should be able to find them listed in this thread. they're one of the most common wheels people use. Whats the ET? IIRC they should work. possible some use a 3mm spacer. but look in this thread in earlier posts. or use the search bar.
Old Nov 4, 2012, 10:32 AM
  #2015
rabbit61319's Avatar
17x?
Will RPF1 17x8 ET35 clear stock Brembo?
With 225/45/17, no spacer.
Thanks!
Old Nov 7, 2012, 05:13 AM
  #2016
cmross13's Avatar
can anyone point me to a thread that lists wheels from other OEMs that are known to fit?
would make winter wheel shopping much easier if i could pick up a set of cheap junkyard/craigslist wheels from an RSX or Accord or something, or perhaps some Rotas from a Subaru owner.
Old Nov 8, 2012, 01:09 PM
  #2017
Received 1,384 Likes on 1,317 Posts
^^^Im not aware of any such list, not saying there isnt one
Probably would be tough to find another OEM wheel w/an offset & spoke design that will clear the front brakes. Most guys run spacers to correct. (personally not a big supporter of spacers although they work well if mounted correctly)
Old Nov 8, 2012, 01:21 PM
  #2018
Thanks!
I know there is a RPF1 in the smaller width size that fits, just dont know for sure that its the one youre noting
Check this thread here: https://www.evolutionm.net/forums/ev...ur-enkeis.html
Personally, those wheels look a bit wimpy on the EVO. Your best looking RPF1's are in the 17x9 & 17 x 9.5 widths but you have to run spacers
My.02
Old Nov 8, 2012, 01:22 PM
  #2019
cmross13's Avatar
Yeah I've had zero luck in my googling lol. Finding some OEM Enkeis locally is proving difficult. Tons of cheap 5x114.3 17x7s in my area tho, mostly from Hondas.
Old Nov 10, 2012, 06:07 AM
  #2020
ebp99si's Avatar
will i need spacers for rx7 wheels?
Old Nov 10, 2012, 06:55 AM
  #2021
^^^My .02
If youre looking for help, Give the full spec of the wheel as well as a pic
Why would you consider RX7 wheels over the EVO stockers
Old Nov 10, 2012, 07:21 AM
  #2022
ebp99si's Avatar
^^^My .02
they're a 16" wheel, more drag radial options than just the 245/45/17 hoosier on the stockers
Old Nov 10, 2012, 07:52 PM
  #2023
^^^Suggestion
Post this up in the Drag Racing forum:
https://www.evolutionm.net/forums/drag-racing-16/
Joe
Old Nov 14, 2012, 06:57 AM
  #2024
Tekniq's Avatar
I would like to buy some XXR 527 in 18x8.75 for an evo8 lowered on swift spec-r. Do I have to roll any fenders?
What offset do they come in?
Old Nov 14, 2012, 05:01 PM
  #2025
ApexEVoIX03's Avatar
So i currently have on my car work cr kai 18x9.5 with Nitto 555's 265/35/18. I dont have my camber setting in front of me but I've gotten the rear fenders rolled and there is still rubbing in the rear over big bumps. I have a little bit of a raked stance currently but wanted to drop the rear more but this is holding me back. I've looked into this setup and I thought I read that someone has cleared this setup.
Here are some pictures that can kind of show how much the rear fenders are rolled. Does anybody think they can get rolled out more? Also Ive asked some people who roll/pull fenders if i should pull them, they all say it requires serious body work due to 95% of the time they buckle badly.
please help! thanks everyone
Quick Reply: Tire / Wheel Fitment Questions
