Tire / Wheel Fitment Questions
Old Jan 7, 2013, 06:42 PM
  #2056
Gordian79's Avatar
whats the better offset for a 17x9 wheel +25 or +35 I plan on 245 45 tires.
Old Jan 8, 2013, 05:53 AM
  #2057
Received 1,384 Likes on 1,317 Posts
^^^My opinion only
The 245/45/17 is a large tire. (For reference, I run the 275/40/17. Circumference's are almost identical)
If you run the +25 you will need rear fender treatment. (roll & maybe a pull & the other tricks used). This wheel will certainly look more aggressive
The +35 will fit, possibly w/out a roll
Old Jan 8, 2013, 04:32 PM
  #2058
Gordian79's Avatar
^^^My opinion only
I may just use stock size tires.
Old Jan 8, 2013, 05:17 PM
  #2059
^^^Run these calculators to help you w/your choices
http://www.rimsntires.com/specs.jsp
http://www.willtheyfit.com
Old Jan 8, 2013, 11:35 PM
  #2060
Gordian79's Avatar
Thanks those are handy.looks like if I run 25 offset with stock tire the wheel will stick out about 13mm towards street side so I think it'll work.Ill measure and see where the 13mm leaves the rim at.
Old Jan 12, 2013, 04:30 AM
  #2061
AdrenalineRush's Avatar
Gonna be running a 245/40/18 Hankook Ventus V12 and the wheels I'm looking at, NOT out yet, are similar to the XXR 521 but are instead the XXR 531 that will be available sometime early this year. I'm looking at the 18x9.5. It comes in a +20 and a +35.
Assuming since the designs are similar I would think that a +20 on these would need a spacer up front for sure and not the rear. I will be rolling fenders if need be not worried about that so much. I'm on Bilstein struts and swift springs FYI
Wheels: http://www.nlmotoring.com/XXR-531-Wh...p/53189542.htm
Old Jan 12, 2013, 07:55 AM
  #2062
^^^Whats your question?
Old Jan 12, 2013, 02:09 PM
  #2063
artinist's Avatar
check out the thread below for some additional info. the 531 wheel has the same specs as the 527 and 530 but the dish looks to be a little less concave and may have caliper clearnace issues up front. the guys at NL motoring are familiar with our setup, give them a call and they should be able to tell you. the 527 and 530 need no spacers in either the 8.5 or 9.5 width but you HAVE to use the +20 offset, the +35 offset is way way off. and you are better off going with 255/35, it clears the rear fender better.
if you are local to them you can always try one wheel on the car to see how it clears the caliper.
https://www.evolutionm.net/forums/ev...l#post10598331
Old Jan 13, 2013, 07:10 AM
  #2064
Well the reason I didn't want to run a 255/35 in that tire is its an extra $30 per tire but if it fits better I may lean that way.
To me the 531 I linked is more similar to the 521 right? Not the 530 or 527 but I could be wrong. The face and concave on the 531 and 521 looks exactly the same.
People who run the 18x10 +25 XXR 521 run a 25mm spacer up front to clear the calipers and none in the rear. My MAIN QUESTION is with the +20 in the 18x9.5 XXR 531 will I need a 20mm spacer up front? I assume that back will be fine. I'm gonna buy this setup regardless when released and make it fit. I assume those size tires and wheels will not be a problem
Old Jan 13, 2013, 10:57 PM
  #2065
artinist's Avatar
the 521 doesnt seem to come in any of the same sizes as the 531, the only similarity is in appearance
Old Jan 17, 2013, 06:50 AM
  #2066
adrianojp's Avatar
I just got the homologation for 265/35 R18 on my trackday Evo8 ;-)
What is the most beautiful and performing set of wheels?
The choice is killing me, am currently looking at Volk CE28N's, TE37SL's or RE30's, all in 9,5J. Not sure of the ET yet, is 35 the best option with rolled fenders in the back?
Any ideas?
Maybe the Advan RS in 9J R18 +29...
Old Jan 17, 2013, 08:26 AM
  #2067
^^^You are already far ahead of most here in the US regarding proper offset
Most new guys are attempting to push the offset as low as possible w/out properly considering fitment
I personally run 2 different sets of wheels: ADVAN RGII 17x9 +29 & a no-name street set-up at 17x9.5 +30. I run a 275/40 tyre on both
The +35 would be your best choice if you are not comfortable w/ rear fender work. I personally like to push the offset just a bit so I would choose the lower +29. The +29 w/a nice 255/35 or a 265/35 would require some rear fender work. You will likely experience some front fender liner rub at full lock, depending on your suspension set-up
Old Jan 17, 2013, 10:36 AM
  #2068
chu
chu's Avatar
^if its a track Evo, as he says, then pushing offset is second to getting the widest tire possible. Offset is all for looks anyway. I say stick with mid to high 30's if there are plans to increase tire size in the future. +29 is the lowest offset I will go.
Local autox guy runs 18x10 +38, 285.30.18 Hoosiers. Don't need to push offset to look good and still perform.
Old Jan 18, 2013, 12:48 AM
  #2069
adrianojp's Avatar
Thank you both for the advice!
I am currently on Ohlins R&T suspension, that should help minimising the rubbing issues, if there are any on the stock setup spring at all...
Quote: Local autox guy runs 18x10 +38, 285.30.18 Hoosiers. Don't need to push offset to look good and still perform.
Won't this setup rub under full lock?
Edit: have seen an Evo with OZ Racing Ultraleggera 9J R18 ET35, this could be my option, as it's very easy for me to get them here, and I think they look really good!
Here are the pictures for another forum:
Old Jan 18, 2013, 04:19 AM
  #2070
chu
chu's Avatar
It will rub slightly at full lock...
Quick Reply: Tire / Wheel Fitment Questions
