Tire / Wheel Fitment Questions
Old Oct 22, 2013, 01:35 PM
  #2401
3vo|3oost's Avatar
What is the best offset for a Varrstoen ES220 17x9 wheel to run on an EVO 8 or EVO9? A wheel company online told me I would have to run +12 offset to make it clear the caliper because of the lip wheel design, along with some fender rolling and negative camber but no spacers are required. Does anyone else have a wheel design similar to this and fit with a different offset? Thanks!
http://www.ebay.com/itm/VARRSTOEN-ES220-17X9-5X114-3-12-73-1-HUB-WHEEL-RIM-FIT-5-LUG-NISSAN-240SX-S14-/400503771264?pt=Motors_Car_Truck_Wheels&vxp=mtr&hash=item5d3fe29080
Old Oct 22, 2013, 05:24 PM
  #2402
Received 1,384 Likes on 1,317 Posts
Originally Posted by 3vo|3oost
What is the best offset for a Varrstoen ES220 17x9 wheel to run on an EVO 8 or EVO9? A company told me I would have to run +12 offset to make it clear the caliper because of the lip wheel design, along with some fender rolling and negative camber but no spacers are required. Does anyone else have a wheel design similar to this and fit with a different offset? Thanks!
Not familiar w/the Varrstoen but have you looked at the Rota Grids, they look very similar. I personally run the Rota P45R which is also similar (5 spoke vs 6)
I believe the Grids will fit w/out spacer. The +12 is not correct & will not fit the EVO Body
Heres a pic of the Grids & also my ride w/the P45R 17x9.5 +30 running 275/40. Let me know what tire you are thinking of & ill run the no.s for you
Old Oct 23, 2013, 10:51 AM
  #2403
3vo|3oost's Avatar
Thanks for the info... I know that wheel design has a lot more to do with the fitment clearing the calipers and with a "backspacing" of 6 inches or more should clear the calipers. That wheel company told me because of the lip design that it needs a lot less offset than stock (+35) and that the +30 wouldnt work since the spokes are pushed in because of the lip is why they told me to go with +12. They have a few different options for offsets in the 17x9, but I just wish I had the wheels in front of me to measure the backspacing or test fit to see if it clears the brembos...
Old Oct 23, 2013, 01:24 PM
  #2404
Happy to help
BTW: The stock offset is +38. If the Varrstoens require spacers, I would rather see you on the ROTAs (same price point & most of their EVO wheels fit w/out spacers)
Old Oct 26, 2013, 12:38 PM
  #2405
DSMTuner326's Avatar
225/65R17 Snow tire fit??
hey guys got a quick question, im looking to buy a set of Blizzak 225/65R17 tires tonight to run on my factory wheels for winter but im worried if theyll fit, im only asking bc im getting them dirt cheap. i have adjustable coilovers but im affraid they might be too tall and rub, does anyone have any experience with this size tire? Any help will be much appreciated!!
Thanks,
Jon B
Old Oct 26, 2013, 04:20 PM
  #2406
Thanks,
Jon B
Hey Jon
Certainly dont have any snow tire experience but, that tire is super tall. Over 3" taller than the stock 235/45. 11% Speedo error (7mph slower at 60mph). In an emergency, maybe, but I would run it for any distance
Joe
Old Oct 29, 2013, 07:42 AM
  #2407
HDA
HDA's Avatar
Originally Posted by HDA
folks, you probably said it countless of times: I need to fit my old enkei 17x9 et 45 in 255/40/17...
]http://s24.postimg.org/5y2ucwrad/img0011mz.jpg
which spacers would I need to fit up front? And are all brands the same thing?
Thanks!
Old Oct 29, 2013, 06:54 PM
  #2408
Thanks!
You should post this up in one of the Enkei threads. Im sure you will get some opinions
Heres one: https://www.evolutionm.net/forums/ev...nkei-rpf1.html
Old Oct 30, 2013, 10:19 AM
  #2409
flippymcbean's Avatar
I have a question. I have set of 18x9.5 rims +35 running spacers up front with 10MM spacer. is this normal? because i see people running same size rim with no spacer. am i missig something?
Old Oct 30, 2013, 12:51 PM
  #2410
Not all 18x9.5 +35 wheels are the same. The spoke design has a lot to do with caliper fitment
If you bought the car w/the spacers on them, the previous owner may have added them for more wheel poke. Its possible your wheels dont need them but likely they do
Wheels that fit the EVO w/out spacers are not that rare but takes some research to find them
Old Oct 30, 2013, 01:55 PM
  #2411
Thanks. Yeah the previous owner put them on. They're FN01RC. I do appreciate the feedback though.
Old Oct 30, 2013, 08:23 PM
  #2412
McSlides's Avatar
17x10 RPF1's +18 on an Evo 8? How much are they going to stick out? I'm getting an awesome deal, but I haven't become too familiar with Evo offsets yet.
Old Oct 31, 2013, 05:30 AM
  #2413
Well, they will poke more than 3/4" further than stock. I ran your no.s using a 265/40 tire & this set-up will require the full rear fender treatment (roll, pull, bumper bolt etc). Also, front fender issues likely requiring the fender spacer kit
Also, run the stock camber! Camber should not be added during the fitment process
+18 is very tough to fit & I wouldnt recommend this if you are going to track your EVO
Old Oct 31, 2013, 07:16 AM
  #2414
spoolinx's Avatar
hope this helps
17x9.5 +18
no spacers
rolled and pulled rears
Old Oct 31, 2013, 09:56 AM
  #2415
McSlides's Avatar
I'll be running 245/40's on them. No added camber, I've heard the horror stories of Evo drivetrain with aggressive fitments. I'll be on Tanabe GF210 springs. Two of my factory wheels got bent pretty bad (don't know how, never hit anything) and I'm getting all four of these wheels near brand new with tires for $1050. I don't want to pass it up. How much rolling and pulling am I looking at?
Quick Reply: Tire / Wheel Fitment Questions
