Tire / Wheel Fitment Questions
#2627
If youre going to run this spec, expect to pull the fender but if you dont have to that is a plus
See this photo here & test fit the wheel & tire. Proper fitment is zero contact through the full suspension stroke
#2628
Hey guys will 18x10.5 +15 on a 255/35 tire fit? I will have all corners rolled, the back pulled and I believe i will need a spacer but I'm not sure what size. The rims are zedd SL5 and I'm on tien springs.
#2629
https://www.evolutionm.net/forums/mo...-body-evo.html
#2630
Ray's gram lights
Looking into purchasing used gram lights t57rc 17" staggered
8" pair and 9" pair both have +38 offset, I have a new set of 4 tires in size 235 40 17 hankooks.
How would this fit, the evo already has pulled and rolled rears and I believe fronts are rolled too. Would I need spacers to make it work?
#2631
Preferably keep all wheels / tires the same spec (tire rotation is important & penny wise). If you have to run a front spacer, then OK
Regarding the +38 & tire size. All will fit well w/much room to spare
#2633
Based on your notes, you should run a 255/35 or even better 255/40 which should fit w/just a roll but will be a tad tougher that the 35 series
#2638
Will the XXR 527 18X8.75 +35 clear the front brembos? Will i have to roll the rear fenders? What is the biggest tire dimension i can run with out rolling the fenders if at all possible!
Thanks in advance!
Thanks in advance!
#2639
Note sure about front caliper fitment
Note: Opinion based on stock rear camber
#2640
MinusPrevious:
What is, in your opinion, the best offset for an 18x9 rim?
By "best" I mean the least fender work in the back and the least spacer in the front.
No flush or extreme offset.
Edit: With 255/40/18's
BTW, thanks for all of your input on this thread, you help a lot of people!
