Tire / Wheel Fitment Questions
Old Mar 28, 2015, 07:39 PM
  #2896
orion4096's Avatar
ssr gtv02 17x9 +38 fit with a 3mm spacer. Without the spacer, the inside edge (closest to the hub) of the front calipers are touching the spokes. With the spacer there is about 2mm of clearance. I have 255/40/17 rs3v2s on the wheel.
Old Mar 29, 2015, 05:23 AM
  #2897
Received 1,384 Likes on 1,317 Posts
That is a very nice shot of the Evo
Old Mar 30, 2015, 07:24 AM
  #2898
Zombie Killer's Avatar
Quick fitment question:
Evo IX on stock wheels. Lowered on Swift Sport springs. 235/55/17 Pirelli P Zero Nero tires. Note the higher sidewall. Will they rub? I got them for a helluva deal so if they won't fit I can probably resell.
Old Mar 30, 2015, 07:43 AM
  #2899
Thats a very large tire in circumference. Calculator shows a -6.8% speedo error. Certainly will not rub due to offset issues but you may get some well rub on a high compression bump
Probably Ok to use temporarily but a better tire size, closer to the stock circumference would be better
Old Mar 30, 2015, 10:23 AM
  #2900
Damn. Thanks.
Old Mar 31, 2015, 07:58 AM
  #2901
Jmills's Avatar
Alright, I have acquired some Enkei RPF1s in 18x9.5 +37 ..... Now I'm not sure what will fit for tires.
I know I need +20mm spacers in the front and none in the rear.
Question is.... WILL I need fender work with 255/35r18s?
Or should I run something a little smaller?
Car is on Tein springs so about 1.5" lower I would estimate.
Any help would be appreciated
Old Mar 31, 2015, 09:41 AM
  #2902
Running stock rear camber you will likely be Ok w/no work but running the 9.5" wheel is going to be close (possible light roll needed). A 245 is the narrowest tire recommended per my chart
Running the large 20mm spacer up front sets the effective offset at +17 which will work but the front fender extender kit may be needed (+17 is a very aggressive offset)
Old Mar 31, 2015, 10:27 AM
  #2903
zk8913's Avatar
Hey!
Quick question 03 evo, will 17x9 +22 te37s fit without spacers? It seems like they do, no one mentions they need them, just want to confirm.
Thanks!
Old Mar 31, 2015, 10:42 AM
  #2904
Originally Posted by zk8913
Hey!
Thanks!
On the average, Volks are Brembo friendly, especially at the lower offsets. Check this thread & see if you can find that spec
BTW, +22 is very aggressive & requires rear fender modifications
https://www.evolutionm.net/forums/ev...37-thread.html
Old Mar 31, 2015, 11:44 AM
  #2905
zk8913's Avatar
I dont mind fender mod. I just dont want to run spacers at all. I saw a few with that spec on that thread but none said if they ran spacers or not. Which is why im think i will be okay, I just want to make sure before I dump $2000 on wheels. lol especially since the set I just got werent the offset I was told and dont fit.
Old Mar 31, 2015, 06:38 PM
  #2906
One of our members PM'd me & asked a question regarding the bumper bolt re-locate. Heres a couple of pics that should take away the mystery of this simple procedure
[IMG][IMG/]
[IMG] [IMG/]
Old Apr 1, 2015, 04:54 PM
  #2907
evo milk's Avatar
How much fender work is needed to run RPF1 18X9.5 +38 on Tein Flex Coilovers? Or what offset would I need to avoid spacers and fender work? Also tire size?
Or what would you recommend for a DD with occasional track use that will not need spacers or fender rolling? I am looking for a medium where it'll still perform well on the track but would not require me to do any fender mods. I would prefer 18s but 17's would be ok.
Thanks,
Old Apr 1, 2015, 05:33 PM
  #2908
Thanks,
Std tire size would be 255 or 265/35 & no rear fender work needed. I havent studied up on the RPF1's in a while, but If I remember correctly you can run those up front w/the 20mm spacer
The offsets that work best w/the EVO rear well are around +32 to +38. At +32, depending on tire size you will likely need rear fender rolling at the min. I track & DD 17's so Im a bit partial to them. 18's track well & the wheel generally looks better on the EVO than 17's
Old Apr 2, 2015, 10:40 AM
  #2909
evo milk's Avatar
Perfect, exactly what I was looking for.
So I think I'll go with the 18x9.5 +38 with 255/40/18.
Thanks man.
Old Apr 3, 2015, 02:01 PM
  #2910
Ryan.Kauz's Avatar
Thank you my good man! The images are very helpful and also give clear indication of how far back it needs to be trimmed.
Quick Reply: Tire / Wheel Fitment Questions
