Tire / Wheel Fitment Questions
#3017
Gram lights 57F 18x8.5 +45 clear both the brakes and struts? Tires are 245/40/18...I'm eyeballing some right now and just want to make sure it fits before getting them
#3018
That offset will look terrible. The same setup, but +30ish would look much better.
#3019
Recommend going through a thread like this & see what the average guy is running. Come back w/what you like & will give you an opinion
https://www.evolutionm.net/forums/ev...el-thread.html
#3020
recently bought a set of 17x9.5 +35 advan rs gtr face and im trying to run a 255/40 it doesnt look like ill need a roll in the front but definitely in the rear. what do you guys think?
#3021
Wedssport SA10r
Hey guys, I'm looking at the Wedssport SA10r for my Evo X, 18 x 9.5 +38. Will they clear the Brembo's? If not, I have 12mm spacers, would they be enough? I was hoping to get these wheels without rolling fenders or adding spacers.
Thanks in advanced for your help!
#3024
18x9.5 on a X you should be getting a +20 offset.
#3025
Does anyone know if the these RX7 Series 8 rims fit with a 20mm spacer? They are 16x8 +50 like the series 6 everyone puts for drag setups.
#3029
Good morning all, I was hoping someone could help me out. I recently bought a stock 06 Evo 9 from my brother as my DD. I will be adding coilovers here shortly. I've come over from the supraforums (1100 hp single) where I've been for a long time and i'm very new to the evo's and looking for some direction. There are three sets of wheels i'm looking at in the fs section. Could someone tell me what fender work needs to be done in order to fit these wheels:
VOLK RacingRE30 - 18x10.5 +18 (bronze)
Volk CE28N 18x9.5 +15 (bronze)
Advan RZ-DF 19x10.5 +15 (black)
Thanks for the help,
Jeff
Jeff
#3030
+22 only works w/significant rear fender work. The full compliment of roll, pull & bumper bolt relocate. Stock camber OK after that work is done
The guys who note it all works well w/the minimum fender work, likely have the following conditions
Rear ride height too high / Rear camber set way over the recommended / Not telling the truth regarding rub (any form of rub means it doesnt fit)
