Tire / Wheel Fitment Questions
Old Oct 6, 2015, 11:53 AM
  #3046
ExRated's Avatar
Looks like front caliper clearance will not be an issue which makes fitment so much easier
Not sure what offsets the LM5's come in. Really depends on how much rear fender work you are Ok with & what tire you plan on running
I.e. 18 x 9.5 +35 running a 255/35 tire will need = Flat rear fender roll at the minimum running in spec camber
I.e. 18 x 9.5 +25 running a 255/35 will need = Rear fender roll, fender pull, bumper bolt relocate etc, running in spec camber
Will the front need a spacer with the 18 x 9.5 +35 to sit flush with the fender? I'm ok with rolling the rear but definetly want to stay away from pulling the fender.
Old Oct 6, 2015, 12:52 PM
  #3047
Received 1,384 Likes on 1,317 Posts
No, +35 is only 3mm away from the stock +38 offset, so the wheel will not be flushed
Its really subjective when it comes to specing the offset to be flushed. Some of the deciding factor will be your choice of tire size
The front fit on the EVO is very forgiving. Best to trial fit this +35 wheel & tire & then decide. IMO, front offsets in the +20 to +24 range are getting on the very aggressive side & may not be best for overall fit. A 10mm front spacer changes this +35 to +25
Old Oct 6, 2015, 03:08 PM
  #3048
jaime8754's Avatar
Im looking into buying a set of volks TE37SL pressed double black. They only offer 18x9.5+22 or +35 which offset will fit my evo 9 the best? Im willing to do a mild rear fender roll if needed. Also i have tein street flex suspension if it helps. professional Opinions please.
Old Oct 6, 2015, 04:55 PM
  #3049
The +22, for sure, looks great & there are many who have run that spec but, the rear fender will need serious work beyond the roll (fender pull, bumper bolt relocate needed)
If you are looking for more of a no trouble set-up & track worthy then the +35 is a conservative offset that works well
Tire size will certainly affect the rear fit
Old Oct 6, 2015, 07:56 PM
  #3050
grat81's Avatar
Hey all -
Looking to do the Enkei T6S 18x9.5 +30 with a 265/35/18 tire on my 8.
I had the same setup on the X, only with a 275/35/18 tire (I know, better clearances on the X - no spacers, no rubbing).
I'm planning on rolling the rears, but am concerned about the fronts. Hopefully I can get by with 5mm spacers up front and call it a day?
Old Oct 6, 2015, 08:15 PM
  #3051
Originally Posted by grat81
Hey all -
Ran your no.s
This +30 w/the 265's will need more than a rear roll. A pull & bumper bolt relocate is in order running stockish rear camber
Not familiar that wheel, but I guess your X needed a front spacer to clear. Running a 5mm up front should pose no real issues. Some liner rub for sure at lock positions but thats the norm
Old Oct 6, 2015, 08:36 PM
  #3052
grat81's Avatar
Thanks for the reply!
The fronts on the X actually cleared without a spacer, believe it or not. I did 5mm all around just to make them flush.
I'll let my fender guy know he's in for some work. I figured I'd have to relocate the bumper bolt.
Old Oct 7, 2015, 07:11 AM
  #3053
tommyf's Avatar
CCW D110's Fronts - 18x9.5 +7 and Rear - 18x10 -3
Will these fit? Help me out please!
Old Oct 7, 2015, 07:44 AM
  #3054
No Sir, Way too shallow of an offset. As a guideline, any wheel below +22 is going to be next to impossible to fit "correctly" on a stock body EVO
(correctly: meaning running stockish camber w/zero rub at all ride heights)
Old Oct 7, 2015, 02:57 PM
  #3055
jaime8754's Avatar
ok then that will probably not work for me. How about the Advan GT 18x9+25. i havent seen any evo 9 pics with this type of wheel but im sure it will look nice. Thoughts on the wheel size and what am i going to need to run this setup?
Old Oct 7, 2015, 03:40 PM
  #3056
Ran these no.s 18x9+25 w/255/35 tire
The tough part is the +25. This set-up will work just fine & almost overlays with my setup (I run an Advan RGII +29) Rear fender roll, fender pull & possible bumper bolt relocate
Front fitment is OK w/no work needed. You will need to make sure this wheel will fit over the calipers
Old Oct 7, 2015, 07:55 PM
  #3057
jaime8754's Avatar
i dont mind doing the fender roll but i really dont want to pull the fender. I spoke with evasive motorsport and they told me that 18x9+25 should work fine with a rear roll. Forgot to ask about clearing brembo. Im sure they would of said something if it didnt clear. Ill call them tomorrow again just to make sure.
Old Oct 8, 2015, 06:25 AM
  #3058
Be careful w/that shop. I had spoken to them about rolling my rear fenders & they, at that time, only cut the rears vs rolling. This was years ago, & ended up working w/Muellerized
Also, Depending on tire choice, +25 needs more than a roll if you are running a non stretched & a properly cambered rear
Just my .02
Old Oct 22, 2015, 01:24 PM
  #3059
KaranS94's Avatar
Here are the options I have, hoping to run a 245/255 tire
1)Enkei RPF1 18x9.5 +38 (20mm spacer to clear front brembos)
2)Enkei NT03 18X9.5 +27(10mm to clear front brembos)
3)Rota G-Force 18x9 +27 or +30(unsure whether spacer required)
4)Varrstoen ES2 18x9.5 +22 or +30(unsure about spacers)
My main objective for the vehicle is back road/ canyon driving and daily driving. What wheel would be the best fit. any help would be greatly appreciated
Old Oct 22, 2015, 04:15 PM
  #3060
They all have potential depending on how much rear fender work you can bear (would steer clear of the +22)
The +27 running a 255/35 will need some aggressive rear fender work (rear roll, pull & likely a bumper bolt relocate) This is running stockish rear camber w/zero rub
The fronts are very forgiving but expect liner rub at lock positions
If it wasnt for the spacer requirement,I would be a big fan of the RPF1's / NT03's
EDIT / Do you have an EVO? Your sig shows Sube
Quick Reply: Tire / Wheel Fitment Questions
