Tire / Wheel Fitment Questions
#3166
These were on my FR-S but are dual pattern and wrapped in 245 s so I want to put them on the Evo
#3168
At what point of spacer do we use extended lugs? I've never had to use spacers before on any of my other platforms but I have some concern about them not being long enough
#3169
You will need longer studs using any type of slip-on spacer. You can always go w/a bolt on spacer which does not require longer studs
example here: https://www.ichibausa.com/ProductDet...de=WS-5511467B
#3170
winter set using stock rims
my evo8 is currently running 18x9 rota g-forces with summer tires on tanabe gf210.
can someone point me in the direction of a usable tire size for a winter set that won't bring ride height/clearance any lower? it's a bit rough as is for NJ.
also, would 255/40/18 work without any rolling? i know a lot of people here use 255/35 for this size. It is also what im currently running, but want to know if i could go a little taller.
Thanks!
Thanks!
#3171
Thanks!
Thanks!
If you give me the wheel offset, I can give you some ideas
#3172
the rotas are +30 with 3mm spacers in front to clear calipers
for the winter set i actually forgot to mention i would be using the stock 17x8 enkeis. i wanted to try and find a size that would fit and if possible keep same/higher ride height/clearance.
#3173
The 40 series tire gives you a 2.7% speedo error which is not too bad. The 35 series is much closer to stock at only 1.2% diff
I didnt ask you if your rear fenders are rolled or if youre rubbing but this setup definitely needs a rear roll & a fender pull to fully clear w/no rub
Solenoid (Mar 5, 2016)
#3174
Thanks!
Thanks!
#3175
I just picked up a set of RPF-1s in 18x9.5+38 for my IX... Does anybody know what I need to make 265s fit? As in what spacers, fender rolling, and what size sidewall? I just want to make sure that Im going to clear the brembos without rubbing on turns and under compression before I get the tires bought and mounted. I wouldnt mind running 255s but Id like them a little wider if possible. Thanks in advance.
#3176
https://www.evolutionm.net/forums/ev...-18x9-5-a.html
A few examples of the 18x9.5 +38 w/20mm spacers noted here
https://www.evolutionm.net/forums/ev...nkei-rpf1.html
#3177
BBS LM 17x8 +35
Can anybody tell me for sure if these will clear the brembos on my 9? If it matters, I have the map stage 2 brake package. If they won't fit, what spacers will I need? Thank you!!!
#3178
https://www.evolutionm.net/forums/ev...st-offset.html
https://www.evolutionm.net/forums/ev...-bbs-lm-s.html
https://www.evolutionm.net/forums/ev...-will-fit.html
