Tire / Wheel Fitment Questions
#3932
Ok, Well the 20mm spacer in the rear converts the Slipstreams to a +20. Heres the overlay between what I run & your proposed set-up
Looks to me like a tight rear fender roll is needed as well as possibly relocating the rear bumper bolt. Note: you are close to needing a rear fender pull as well.
The clearance is certainly not with the wheel but w/the tire as you can see in the overlay
Not sure how low your EvO sits, but if its squatting hard during a launch, for sure, you will need clearance between the tire & the the rear fender
With the 22mm spacer up front that changes your Slipstream offset to +18 which looks OK w/no fender rolling needed (rolling the fronts is very tough due to the alum fender) You will likely have some front liner rub depending on ride height
Please double check these American tire size conversions to metric before making your final decision
Also, I would think there are other drag EvO owners running this set-up?
pls1968 (Jul 23, 2018)
#3933
Good looking out!!
MinusPrevious (Jul 23, 2018)
#3934
Originally Posted by pls1968
I have another question, you answered my last question as it pertains to using that tire with my current spacers and Brembos, what if I install the STM small brake kit out front. Would I be able to use the setup without spacers without any more fear of rubbing? By the way I have D2 adjustable coil overs that I can also raise to help with clearance. Your help is greatly appreciated as I will need to make my decision within 2 days in order to confirm having them here before the shootout.
So, if you just ran the Slipstreams in the rear at the +40 it will overlay like this Vs my setup. This will certainly be no problem with the outboard fit in the rear. No fender work required. Plenty of clearance!
I was concerned about the inboard side, but if this overlay is accurate, you should be clear of the lower trailing arm & the rear coilover
Let me know if you have questions / comments
#3935
^^^Re-doing calc using a 255/50/16
Not too much diff than the 26". The only issue is that these tires are really pinched on the narrow 7" wheel, but if the tire is meant for the low pressures of drag, maybe its OK
Fitment is not any different. See image below (just a tad wider)
#3936
#3945
kaj (Aug 2, 2018)
