Tire / Wheel Fitment Questions
#3991
I am going to test fit some 17x9 +45 RPF1s on my car over the weekend. We will see how big of a spacer it will take to clear the calipers up front! I dont think its going to be a very good outcome though. At least I will be able to contribute something to this thread.
#3992
Yeah, thats a tough one at the +45. Very likely will have issues in the rear contacting the rear lower control arm
The proven RPF1 recipe is usually the 17x9.5 +38 w/a 20mm spacer up front. They just look excellent at this spec
#3995
ok so how about this setup konig hyper grams 17x9 +40 on 255/40s? or am i just reaching at this point ....and any feedback on the michelin pilot 4s? my buddy swears by them?
#3996
really I'm just trying to grab something, stock rims shot and i want to get car back on road and will get stock size 17X8 with 235/45s if i have to and plus konigs are cheap and the rate I've gone through rims in terrible NY roads might be best bet.
MinusPrevious (Dec 14, 2018)
#3997
That Konig 17x9 +40 will fit in the rear, no problem (although you may be getting the tire close to the lower control arm / check for that). Up front, likely a spacer will be needed. (thats the tough part). Unless you know of some information on others that have run that wheel, front fitment is going to be a test fit.
Might be better to just get a set of stockers & run those? (we know those fit haha)
These high positive offset wheels usually have very flat faces & dont look the best
#3998
so i'm currently running the ce28 18x9.5 +34s that I spent months searching for. I've also got ce28s in 18x9.5 +28 on the way. I'm going to look at the current set to see how much extra poke I can afford, but I think with ~-2 degrees of camber in the rear I'll just be clear of the fenders, which are rolled. I have not had to remove/relocate the rear bumper tab for the +34s, I will be surprised if I need to for the +28s.
#3999
Its going to be tight Sam. Im running both a +29 & a +30 set up on a 17x9 & 17x9.5 (not at the same time)
Im right at the edge of full, no rub fender clearance at -2° and with a rear pull & bumper bolt relocation. Im running a wide Fed 265/40 (it measures the same as a 275)
What tire?
What tire?
#4000
Im right at the edge of full no rub fender clearance at -2° and with a rear pull & bumper bolt relocation. Im running a wide Fed 265/40 (it measures the same as a 275)
What tire?
What tire?
I'm still not seeing how the bumper tab has to be removed, but once I get the car put together I'll take another look
#4004
ok so I've been looking at rims for what seems like weeks now and i found this guy who has konig hypergrahms 18x9.5 with 255/35s and has no spacers and no rubbing/fender modification. anyone have any feedback on this?
