Tire / Wheel Fitment Questions
#4729
Not sure how that template idea would work but i like your thought on that
#4730
The test fit would be the best if that's possible using washers or other stackers to get the 3-4mm of caliper to spoke clearance needed. @ +45, you know, it will likely be 20mm or more depending on the spoke & hub layout.
#4731
Didnt know what you were up against regarding a test fit. Another issue to consider is a spacer will be needed front & rear which is not optimal but certainly works
Heres a BMW type Brembo template. Maybe searching this site / contacting them they can produce an Evo Brembo template?
https://www.racetechnologies.com/art...rake-clearance
#4732
I found a Stoptech ST40 template with 332mm rotor, worst case I buy a StopTech kit if it works? Spacer up front is expected, I'm not worried about the rear.
https://centricparts.com/SiteData/me...2450-02_FP.pdf
#4733
Im sure you have your reasons but why not run the Regamaster 17x9 +34? You noted, youre not worried about the rear, but a spacer will be needed there as well, not for the caliper but the lower trailing arm.
Hey, been a 17" guy since 2008, but found wheels that dont need spacers as the car was tracked and didnt like the the idea of running spacers in a high load environment.
Keep us posted on your search & if you get these, post the pics & note which tire youre running (255/40 or wider)
Cheers sir,
Cheers sir,
#4734
Cheers sir,
Cheers sir,
#4737
As far as the no rub thing, depends on tire size & rear camber set! Im running 275/40's & mine dont rub a bit (wink, wink. Ive had the rear work done)
#4738
actually I would say a 17x9 or 18x9 is the optimal size for the CT9A without having to do mods to your fenders. Offsets in the range of +30 to +35.
A 9.5 rim, even at conservative offsets and running a 265 which would be what most functional oriented folks will recommend will cause rubbing even when the car is lowered conservatively (say with Swift Springs on stock struts).
If the TE37 is what you are looking at and you want the concave face, the best option are the TE37 Sagas as Rays has changed the offsets a bit around on this wheel to allow more concave for lesser aggresive offsets.
Normally you have go with an offset of +22 to get the concave face on the standard TEs and its SL variant.
If you look at the chart for the Sagas on their site, the 18x9.5 +31 now comes with the concave face and the offsets is much more forgiving then a +22 when trying to get them to fit with a proper size tire... say a 265. Even with a +31 you may still rub in the rear depending on how low your car is. Also, I mentioned the +31 because according to their chart they will clear the calipers up front.
https://www.rayswheels.co.jp/product...wheel=TE37SAGA
#4739
Well, the noted size is certainly OK & the +35 helps w/rear fitment. You are certainly in the right size area to fit the rear CT9A!
The question that needs answering is: Will this wheel (unknown brand & type) fit over the front Brembos? If not, a spacer will be needed at some thickness.
Also, depending on tire size a rear roll may be needed along w/some aggressive camber
#4740
Originally Posted by frsh92laser
I have recently upgraded to some ohlins coilovers and can really feel how bent my wheels are. I am interested in a set of volk te37 but dont know much about changing diameters , widths amd offsets. Ideally i would like to go 18” bolt on offset etc, can you recommend a size.
Hello. Posted you up here so its easier to reply & add pics if necessary. Have you gone through this thread yet? Let me know what peaks your interest & let me know what size & offset you like. I can do the layout for you & give you a fitment opinion
https://www.evolutionm.net/forums/ev...37-thread.html
Depends on your appetite for rear fender work. If you want minimal rear fender work you will want to look for wheels in this range:
- 18x9 +34 to +36
- 18x9.5 +35 to +36 (depending on tire size rear fender work needed)
- +22 to +27 are tough to fit in the 9 to 9.5" width
