Tire / Wheel Fitment Questions
Old May 11, 2008, 07:35 AM
  #466
jbrown's Avatar
Originally Posted by 5h3r42
hi can someone tell me what the exact fitment for the evolution 7 is please, i want to buy a set 18" for my evo 7 and i dont want the rear arches to scrape the wheelsi will be lowering the car with tein springs.
17x8 +38mm on 5x114.3 pcd with a 67.1mm center bore, same as the Evo 8 and 9. I'm pretty sure the 7's were available without the Brembos in some markets, so I have no idea what you have or what kind of brake clearance you will need. If you have the Brembos then everything is exactly the same as an Evo 8 or 9.
If you're in London, call Unit 8, they know their stuff. www.unit-8.co.uk
Old May 15, 2008, 05:56 AM
  #467
chu
chu's Avatar
Fitment for 17x10 +25
I'm able to get a good deal on some 17x10 +25 5Zigen FN01-C. Wondering if anyone knows of fitment issues, and what size tires I should run. Thanks!
Old May 22, 2008, 11:50 AM
  #468
BippuBoss's Avatar
i just went to check out the SSR wheels, I didn't realize they had added more wheels! the Type F's are killer on that Evo X it's so exciting. I wonder if they will fit the Evo 8 or 9's? Sorry just excited no time to look at sizing.
Old May 30, 2008, 07:09 PM
  #469
BestOFbothWrlds's Avatar
Hey I got a 2005 oz its a 4 lug pattern what's a good agressive size that will fit nicely
I have 17x8s on my subaru but I don't kno if something like that would fit my oz
Old May 31, 2008, 02:43 AM
  #470
akemi27's Avatar
tires for the X? thx
not quite sure what size r the rims
https://www.edgeracing.com/2005/Mits...tion/tires/18/
http://www.discounttirezone.com/Falk...c_336-3-3.html
...my options so far
Old Jun 1, 2008, 08:47 AM
  #471
greatgonzer's Avatar
Originally Posted by tnhockey
thanks bro. but unfortunately i just called them and they said none of their wheels will fit an evo. they said theyre having the hardest time getting wheels to clear the brembos. back to square one.
Interesting. Since www.BigWheels.Net has the SPORTMAX 006 18 8.65 35mm offset as fitting the EVO specifically. You can even go and choose tire selection and many of them show as "fitting" the evo on that website...
Old Jun 18, 2008, 08:22 PM
  #472
03evo8q's Avatar
will a 17x9 +45 RPF1 fit with no problems?
Old Jun 19, 2008, 05:56 AM
  #473
chozen1's Avatar
Does anyone know if I can fit a 18x10+18 on a Evo 9 stock fenders or will i have to roll/pull the fenders?
Old Jun 19, 2008, 06:44 AM
  #474
jbrown's Avatar
You will definitely have to roll/pull/pry/bend/beat with a hammer. They will stick out almost 2" more than stock wheels, but will be close to the same spot as the stockers on the inside.
I'd suggest you call Robert @ Robispec as he has done wheels with similar dimensions numerous times. You may even be able to have him do it for on his next trip to your area.
Old Jun 19, 2008, 06:51 AM
  #475
jbrown's Avatar
If by "with no problems" you mean "with a 12-15mm spacer" the answer is ... probably, but the RPF1 looks odd in high-offset fitments. The spokes have a funky curve to them and it will make your car look like a front-drive base Lancer. There are a lot of fitments that work without a spacer, I'd look at those first.
Old Jun 20, 2008, 04:31 AM
  #476
theshadow's Avatar
a question for jbrown/speedelement (who appear to be the wheel gurus!)
I'm looking to run 285/30/18 R compund rubber (either Hoosiers or Yoko A048s) and would like to know if you guys could help me with a list of possible wheel options that would allow these to clear the stock bodywork.
I run KW V3s, have the rear fenders roleld and pulled and run '1.8 camber rear, -3 front.
Hope you can help - I know that the ideal rim size would be an 18x9.5 or 18x10 but the brands and offsets that would allow this are totally confusing to me even after some heavy searching.
Thanks if you can help!
Old Jun 20, 2008, 08:23 AM
  #477
jbrown's Avatar
Robert from Robispec can tuck some Enkei NTO3+M wheels in there for you, but it involves the liberal use of a large hammer in the fenderwells. I think he uses a custom offset as well, but I'm pretty sure it works without spacers, so that's the ideal situation. I have seen him do a 275/40/17 like that without problems.
Any wheel that can hold that much rubber is gonna require some modification to the body. Robispec does it on the inside so you don't need wider fenders or a widebody kit.
You can also look into the superlight (16.1lbs) Buddy Club P1QF in 18x10 +35mm. It will probably need a small 5-10mm spacer up front and some fenderwell mods too. I run the 17x9 +28mm without spacers on a 255/40/17 and am very happy with them.
You might want to pm nils or Robi as they both have more experience than me in this area.
Old Jun 20, 2008, 01:51 PM
  #478
theshadow's Avatar
Thanks for the tips, jbrown
I'm not averse to hammering the fender wells in at all - in fact I've already removed most of the inner fender liners already in the front due to rubbing issues.
Excellent tip on the Budy Club P1QFs - never imagined I could run big AND lightweight at the same time! If you're confident a +35 offset would fit under there then I may well bite the bullet on those...not cheap but good stuff never is it seems (when it comes to rolling stock at least).
Will also check with Nils and Robi...I think Nils runs some big Enkei NT03s...not sure of the offset or tire...
Thanks!
Old Jun 23, 2008, 06:24 PM
  #479
Disciple1's Avatar
Couldn't find it listed anywhere in this thread.
I'm looking to get Advan RS, I have stock Bilstein struts with HKS Kansai springs and my tyres are 245/40/18.
I want to know what size rim and offset will make the best fit, preferably without rolling the rear guards or changing my tyres.
I was looking at 18x9 +29, but I've seen people have trouble with a 245/40/18 tyre.
So, maybe 18x8.5 +30? Suggestions?
Old Jun 23, 2008, 07:21 PM
  #480
jbrown's Avatar
Assuming you have an Evo VIII or IX ...
18 x 8.5 +30 is like a drunk fat chick ... a sure thing
18 x 9 +29 is like the flirty hot chick ... a little bit of work (rolled rear fenders), but totally worth it (seriously concave).
235/40 is a good size if you want to take the easy way out, works on the 9" too.
255/35 is good on a 9" but like the flirty hot chick, your choices are slimmer. It's very close to the stock tire diameter, but a tight squeeze even with rolled rear fenders.
245/40 is a bit taller than stock, but it may clear the fenders better because it's narrower. Not as common a size over here, so I can't say how well it will work.
Quick Reply: Tire / Wheel Fitment Questions
