Tire / Wheel Fitment Questions
Old Sep 17, 2008, 10:18 AM
  #586
jbrown's Avatar
Originally Posted by STIKiller4G63
Do you have a better tires size I can use that is still thick? its the rotas p45r 17x9 +25 for sure
245/40 might work, but +25mm is a very aggressive offset, you may need to run the stock tire size for it to clear.
Old Sep 17, 2008, 11:13 AM
  #587
STIKiller4G63's Avatar
well I have 10mm wider fenders from the oem ones
Old Sep 17, 2008, 11:42 AM
  #588
Hikaru's Avatar
^would have helped to know that in the first place
Old Sep 17, 2008, 01:27 PM
  #589
jbrown's Avatar
Thanks for including that nugget from the beginning, LOL
Then it probably won't rub in the front, but you're still gonna need to roll the crap out of your rear fenders.
And to answer your PM, yes, 255/40/17s will fit on 17x9.5 wheels just fine. But whether or not it rubs is a completely different story. 9.5s are obviously harder to fit than 9s. A 17x9.5 +30 will stick out further than a 17x9 +25 by about 1-2mm.
So to answer all of your questions at once:
If you don't want to roll your rear fenders, get a 17x9 wheel with a +30 to +35mm offset and 255/40/17 tires and stick a 10mm spacer up front to fill your wide fenders. Most 17x9.5 wheels ain't gonna work in the back without rolling.
Old Sep 17, 2008, 01:39 PM
  #590
Thanks! I might try to give it a -2.00 when I get cambered
Old Sep 17, 2008, 02:38 PM
  #591
jbrown's Avatar
I wouldn't try to give it anything. Call Robispec.
Old Sep 19, 2008, 12:25 AM
  #592
jdmdingdong4u's Avatar
just put on the direzza's today...and i must say...very grippy, less noise than the advans...very happy with my purchase...255/40/17 on the stock wheel...only put on about 30 miles on it...havent really drove on it too crazy...
thanks for the help jbrown, hikaru
cant wait till i get the rg2's now...
Old Sep 19, 2008, 07:47 AM
  #593
Hikaru's Avatar
^ Nice man! Throw up some pics when the RGs come in...
Old Sep 20, 2008, 07:13 PM
  #594
boostedwrx's Avatar
Good thread guys lots of excellent info!! I wanted to get some more input on some CE28N's I'm looking at.
I want to run 17x9 but don't know how aggressive the +35 offset will look. Obviously there won't be any rubbing in the back and I could probably run a 5mm spacer up front but would it look much more aggressive than stock?? I don't really want to go 17x9.5 and +28 though to get a nice look. I'll have to get bigger tires plus roll the rear. I'm looking to stay lightweight both with wheels and tires so 17x8.5 or 17x9 is probably what I'm looking at.
Old Sep 21, 2008, 11:41 AM
  #595
jbrown's Avatar
17x9 +35 will look more aggressive than stock. They will stick out about 15mm further.
IMHO, one of the best aggressive looks without a ton of work is a 18x9 or 17x9 +29mm Advan RS. Those will stick out 20mm wider than the stockers and have a sick concave face. You need to roll the rear fenders, but that's about it.
17x9.5 +28 will be a bit of work in the back, but if you can find something in the +35mm range, you might be able to get that to tuck in with just some fender rolling, but you'd have to run a different offset or use spacers up front and I'm not a fan of either of those options.
Old Sep 24, 2008, 05:17 PM
  #596
Charlie87's Avatar
hey guys im from australia and just got my evo 8 mr, ive been readin through all ur posts but havent came across something that will answer my Q.
im currently looking at a set of gram lights 57pros with a titanium lip in 18x9".
questions:
1. will i need to work the rear guards? (im pretty sure i have to cause ive read it somewhere here b4, but just wanna confirm)
2. does staggered offset mean the front offset is different to the back?
3. what offsets will i need so that they will clear the brembos front and rear? (i want the rear to have as much dish as possible)
4. im pretty sure ill need spacers, i read sumwhere on this thread ill need a 5mm spacer? (just asking to make sure as i dont wanna get it wrong, cause theres no refunds )
thanks for the help guys!
Old Sep 24, 2008, 06:48 PM
  #597
jbrown's Avatar
questions:
1. No clue, depends on offset and tire size, but it should be minimal unless you get aggressive with the offset.
2. Yes, but usually this is for RWD cars as the rear wheels are wider as well. Not very common on AWD cars, but some autocross ppl do it for handling reasons.
3. For an 18x9, you want to be in the +32 to +35mm offset range with a 255/35/18 or 235/40/18 tire. The 57pro is available with 3 different faces. The "A" face is listed as clearing the big brakes on a Lancer. The standard "A" offset is +12mm though. So I would recommend the "B" face in a +40mm offset with a 6-7mm spacer. But I'm not a fan of 5-spoke wheels on an Evo. You can get the 57SPro in the "A" Face and +33mm offset and shouldn't need any spacers.
4. You only need spacers if you buy wheels that don't fit right. I personally despise them. They often cause vibrations because they are difficult to align and if you don't use extended studs, you don't get a whole lot of threads in the lugnut, which can be very dangerous for anything more than a 2-3mm spacer.
Please do a little more research. I'd hate to see you stuck with no refunds on a wheel that doesn't fit properly.
Old Sep 24, 2008, 06:58 PM
  #598
Charlie87's Avatar
thanks jbrown, youve been alotta help!
can u recommend me an offset for a 18x9" rims with NO spacers? im not too fussed about the staggered offset. i know i said around 32-25 offset but wot would u recommend? with no scrubbing issues, cause i had major scrubbing issues with my previous car and it killed me :S
Old Sep 24, 2008, 07:54 PM
  #599
jbrown's Avatar
re-read the first sentence on my answer to #3.
Old Sep 30, 2008, 12:28 PM
  #600
rawkus's Avatar
jbrown,
I am currently running 17x8 RPF1's with 255/40 17 Azenis with a 35mm offset. I am not a fan of how much the tire rolls at autocrosses and track days so I was considering going with a 17x9.5 RPF1 with 38mm offset with the 255's again. First, would I have to be concerned about these wheels fitting over the brakes? Second, would I have to be concerned about rolling the fenders with the same width tires? Thanks a bunch, I will continue searching on my own as well.
Dan
Quick Reply: Tire / Wheel Fitment Questions
