Tire / Wheel Fitment Questions
#1306
Sup guys, I just need to know the bolt pattern for a 2007 Lancer ES. I've been looking like crazy and all I have found is that the 2006 Lancer has a 114.3.
I'm looking to put Enkei EV5s in a 17 or 18 inch.
#1307
guys just went with some TE37 SL 18x 9.5 +22 gathering going to have to roll the guards (car is in the shop atm anyway so easy to do).
Also what tyres size max would I lok out without having to switch to widebody?
Oh Evo 8 for those not looking....
#1311
rims size choice. heep me choose right please
hey i didn't find any real info on the rpf1 when comparing.
so im looking into getting a set of rpf1's and would like to know if there will be any fitment problems between these two sizes.
18x8.5 +35 and 18x9+30... these are the sizes im looking at
will i need to role fenders?
will i need spacers?
i want to just throw them on and go...
#1314
There are several threads on the RPF1's for info. As far as I have seen, the 18x8.5 fit, you must do modification to front fenders with the 18x9 AND use a smaller width for the rear.
#1320
Hope this is NOT a repeat:
WedsSport TC105N 17X9 35mm offset with 245/40 tire will need 3mm spacer up front to clear brake calipers and nothing in rear. NO rubbing or fender modifications required. Ride height is set with front lower control arms almost parallel(center of driveshaft to fender F=15in R=14.25in).
Murph
Murph
