Tire / Wheel Fitment Questions
Old Jun 20, 2005, 09:41 AM
  #121
lancealot72's Avatar
Originally Posted by Mr.MR
Those are perfect. Where did you get them and how much? What Toyos are those? Do you know the weight of the wheel and tire combo? Your Evo looks great, nothing beats a clean black car.
I got the rims from Discount tire direct for 200 a rim and the tires are the Proxes 4. I cannot remember the weight of the combo, but i think it came out to be same as stock, if not it was either a few punds over or under. Sorry not much help with the weight, but i cant remember.
Let me know if you have any other questions.
Old Jul 14, 2005, 07:47 PM
  #122
yia_lanevo8's Avatar
I'm having trouble...my car is drop with Tein S springs...which rims will fit perfectly without rubbing...i'm thinking about 18x8.5 or 18x9 SSR SP1 PROFESSOR. which should i go with 8.5 or 9, offset and tire sizes? please help me out.
Old Jul 14, 2005, 08:52 PM
  #123
machron1's Avatar
Ummmmmm maybe read this thread it's 9 pages long with all kinds of offsets and tires...it might give you an idea...
Old Jul 19, 2005, 06:25 PM
  #124
barney malone's Avatar
machron1: Ummmmmm maybe read this thread it's 9 pages long with all kinds of offsets and tires...it might give you an idea...
Or, if you are really that lazy, you might at least look at the summary I put together on page 8 (post #115).
And while I am posting, I thought I might mention NOT to try the Enkei RPF1 17x9 35et because they hit the front brake calipers (although you could use spacers on the front). This was surprising since posts here said (and I believe) that both the Enkei RPF1 17x8.5 30et and 40et both work. Oh well, you have been warned.
Old Jul 28, 2005, 05:11 AM
  #125
awdjunkies's Avatar
Does anyone know if the size 17x8.5 with an offset of 40(Lug pattern of 5x120) Fit my '03 evo??
Thanks
Old Jul 28, 2005, 09:40 AM
  #126
machron1's Avatar
Needs to be 5x114.3mm bolt pattern.
Old Jul 28, 2005, 02:22 PM
  #127
awdjunkies's Avatar
Thanks Machron1
Old Aug 2, 2005, 09:31 AM
  #128
shivaswrath's Avatar
Originally Posted by Gruppe-S
Below is a list of sizes and fitment that will fit 2003+ EVOs.
Weds SA90 17x8.0 5x114.3 +35mm, 16.0lbs each
Weds SA90 17x9.0 5x114.3 +35mm, 16.5lbs
Available in Bronze and White.
Weds SA70 17x9.0 5x114.3 +35mm, 16.8lbs each
Weds SA70 18x9.0 5x114.3 +35mm, 17.4lbs each
Available only in Bronze
[B]Weds TC005 17x9.0 5x114.3 +30mm, Availabe in Silver, and White.
I hate quoting big posts like this, but how much do the Weds TC005 17x9.0 5x114.3 +30mm weigh in the 18" size? Tirerack has them listed as a proper fit for us and they look HOT, but I have no idea how much they weigh. . . .
Old Aug 2, 2005, 09:49 AM
  #129
Neal@tirerack's Avatar
My techs are saying 18lbs.
Old Aug 2, 2005, 09:56 AM
  #130
WOW, 18X9 Weds TC005 only weigh 18lbs?!!! That's a helluva lot lighter than the OZ's that fit the EVO platform. . .at $519 a rim, that's not too bad. . .are they fully forged? T-Rack doesn't list how these rims are made. . .
How much do they weigh with 235/40-18 Potenza S03's??
Old Aug 8, 2005, 06:23 PM
  #131
bovbilly's Avatar
WILL ENKEI NT03+M, +38mm OFFSET, FIT ON AN EVO LOWERED WITH SPRINGS, WITHOUT SPACERS?
OH YEAH, RIM IS 18X8.5
Old Aug 12, 2005, 07:23 PM
  #132
Ippatsu Man's Avatar
Hello
I was wondering if those 2 wheel models would fit a 05 Evo8 ?
CP-035 ( 13.6 lbs ) , size 17x8 , offset +38mm , on stock tires
and
CP-S10 ( 18 lbs ) , size 18x8 , offset +36 or +42mm , with 235/40/18 tires
Thank you for any info ^^
Old Aug 22, 2005, 02:44 AM
  #133
Bebe_82's Avatar
hi
hi. i need some help from you guys.
if any body know the axis hiro 18x8.5 can fit on the evo.??? if what side of offset i need??? and what side of tires???
thanks
chong
Old Aug 31, 2005, 07:19 PM
  #134
evo8dad's Avatar
Curious to know if anyone is running 17X9 5-114.3 27GM. I saw that a 27mm offset will fit but on a 17x8 wheel.
Thanks
Old Sep 8, 2005, 09:35 AM
  #135
d2sEvo's Avatar
im planning on getting the black racing n1's in 17x8 with a 35mm offset. Does anyone have pictures and will they clear the front calipers? Any recomendations?
Quick Reply: Tire / Wheel Fitment Questions
