Tire / Wheel Fitment Questions
Old Nov 22, 2010, 05:27 AM
  #1366
MISHI's Avatar
Again, coming back to my Rota +30 question... if you do have to use a spacer, what do you recommend? I saw a company called t1r selling 3mm spacers... are they good a brand? Was checking for ichibas which i currently use in 5mm and they don't do smaller than that.
Old Nov 22, 2010, 08:06 AM
  #1367
Frank120's Avatar
rota grids...
i need your guys help i want rota grids but idk which to get im not that good with rims so bare with me on this.. i have a rr evo 8 and idk which is best bronze or flat/gloss black. my windows are tinted 20% if that will help. let me know best size and off set. im looking at 17 by 9 i think
Old Nov 22, 2010, 05:14 PM
  #1368
Hikaru's Avatar
Originally Posted by NativeSS
anyone have the numbers for the backspacing on the CT9A?
stock offset is +38 I believe.
Old Nov 22, 2010, 10:50 PM
  #1369
D Grade's Avatar
Well, Rota's are Rota's. lol Depends on your color preference, but Ill tell you this, if my Evo was RR I'd definitly be going with a flat black wheel if I was settling with a Rota. The Grids are nice, so are the G-Force wheels. Not sure if they make subzero's in a reasonable offset or size for what Evo's would ideally run.
For my CE28N's, I run a +28 offset, 18X9.5's using Toyo T1R's in 245/35/18. If I could go back, I would have gotten a 255 but it's not bad as is. They are perfectly flush with the fenders and dont rub under any circumstance (lowered on Tein S-Techs/stock shocks at the moment). I imagine if I went with a 17", I would have gone a similar setup with the exception of 40 series instead of 35 series tires.
If you find a higher offset wheel, you can always retort to spacers (preferably bolt ons like hub-centrics).
Old Nov 22, 2010, 11:12 PM
  #1370
AdamWest's Avatar
hard to say man.. but i would go with a gloss black grid if i was in RR. always thought it looked good what springs/coilovers are you runnning??
Old Nov 23, 2010, 07:16 AM
  #1371
Frank120's Avatar
stock heright
Old Nov 23, 2010, 07:17 AM
  #1372
Frank120's Avatar
thanks man ill look into it. i really like flat black but do you think it will look odd with alot of gloss black stuff on my car?
Old Nov 23, 2010, 12:54 PM
  #1373
D Grade's Avatar
Naw, I prefer the sporty look of flat black. I think gloss black looks cheezy if that maks any sense.
Old Nov 25, 2010, 05:33 PM
  #1374
Nastynine's Avatar
Question: Will 17x7.5 wheels with a 5x114.3 pattern and a +45 offset fit??
Found an amazing deal on these wheels and I want them for winter
The specs are:
17x7.5 with a +45 offset
The bolt pattern is correct. (5x114.3)
Question is, will I be ok with that offset?? Will i be ok with the brembo brakes?
Will I need spacers?
I don't mind buying spacers iff necesary.
Thanks
Old Nov 25, 2010, 07:48 PM
  #1375
Jerm__'s Avatar
If your buying them from a private sale, just do a test fit right in front of the guy and if they fit, buy them then.
Old Nov 25, 2010, 10:09 PM
  #1376
JohnDoe1984's Avatar
What do they look like? It helps if there's a nice outward curve to the spokes. That offset if going to throw the face of the wheel a little more towards the outside of the rim compared to stock and pull the wheels in from the fenders but the reduced width is going help clear stuff. I'd probably run a 215/50. That would be a good winter size for a 7.5" wide wheel.
They might fit, they might not it's hard to tell. Evo's can present a challenge for wheels that fit. Just for a joke I went to the local tire store to see if they could at all compare to online prices for my winter setup. Les Schwab told me they only had one wheel in their catalog that fit the evo. I looked at it. It was ugly as sin and they wanted over $230ea. just for the wheels.
Old Nov 26, 2010, 06:58 AM
  #1377
03whitegsr's Avatar
They probably won't clear the brembos. Very few wheels clear the brembos without spacers. Most of them are in the <30 offset and have been designed to clear large calipers.
Old Nov 28, 2010, 07:34 AM
  #1378
rhd-jon's Avatar
happen to me i tried running 17x8 +35 desmond regamasters and no luck not even with a spacer i would need extended studs to do so. So i have them up for sale and bought diffrent wheels
Old Nov 28, 2010, 03:34 PM
  #1379
Go_Lancer_Go's Avatar
265/35/18 on 18x9 rims
So I wanna buy Nitto NT-05's however
I don't think they make them in 255/35/18
So next option is 265/35/18. I have 18x9 +29
Advan RS's
I wanted to know if anyone had any pics so I can see how "beefy" the tires would
Be.
Decisions, Decisions
Old Nov 28, 2010, 03:39 PM
  #1380
healthynine's Avatar
I have no pics, but I was planning this setup on Advan RZs. From what I gather, they will fit well...
But also in for some pics.
Quick Reply: Tire / Wheel Fitment Questions
