Question on wheel specs/camber...etc
Im about to install my megan street adjustable coilovers with stiffer springs in the rear (8kg instead of 6kg) I also have some new rims coming in. (18x9.5 Rota P45R2 w/ 25 offset) I will be using a 5 or 10mm spacer up front to clear the Brembos. Tire size Im going with 245/40/18
Im looking not to rub in the back. (Fenders are rolled and reason for stiffer springs to help) I wanted to know if anyone was running a similar setup (NOT EXACT) that dialed their camber/toe etc.....to something different. (negative camber...etc)
What are some dialed specs that some people are using for their rims to help with tire fitment?
My buddys tire shop is hooking me up all at once so Im trying to get close to the right numbers to get them dialed at.
Thanks
TK
Thanks
TK
track or DD street? you should get some bigger rubber for those tires and just not slam it so low so you can utilize the full width of the wheel. but that being said, your choice, just let us know what your intended application is for better suggestions.
ex: street: -2 front -1.5 rear.
Track: -2.5/3 front, -2 rear. etc
gl bro
gl bro
Its not a DD anymore but i use it to travel to car shows in Colorado, car meets, weekend driver(nice weather) and some track time. (Maybe 3x's at the track this summer)
Dont plan on slammin it or lowering it to much. Dont want it tucked. The roads are not as perfect...lol
GTWORX.com
402
Dec 17, 2018 10:31 AM
Aby@MIL.SPEC
15
Apr 10, 2018 05:12 PM
LSD Motorsports
Vendor Classifieds
10
May 18, 2017 03:19 PM
ErikB
Aug 11, 2010 10:29 AM
