FD wheels on the street
Old Mar 3, 2011 | 01:08 PM
Donkeypuncher's Avatar
I know the FD wheels are big for drag which is what I like to do. I was wondering if there are any big negatives about possibly using these wheels for daily driving. Any help would be appreciated.
thanks
Old Mar 3, 2011 | 01:44 PM
sho669's Avatar
Don't see any issues as long as you have the correct spacer to clear the brakes. I'm sure what ever set you find has already seen it's fair share of street miles before you picked them up.
What are your concerns?
Old Mar 4, 2011 | 12:25 PM
Thanks, not sure of concern really, I guess just the fact that they are 16 inch and at one point had to be reinforced so the design changed. Im thinking that I should get the later version if I am looking to daily drive on them.
Anybody use these as DD?
Old Mar 4, 2011 | 12:34 PM
erald01's Avatar
why??? your stock OEM are a lot better, the only reason most ppl use them is because they are small enough to fit the slicks on and because they actually fit our cars.
Old Mar 4, 2011 | 01:39 PM
Well thats what im trying to find out. Why are the OEM a lot better than a set of FD? I know that the FD are lighter so that makes them better so far. Im running X MR wheels at the moment on my 8 RS
Old Mar 4, 2011 | 02:04 PM
EvoDan2004's Avatar
stock bbs 17 inch rims are 17.7lbs each
fd non enforced rims are 13.8
fd reenforced are 15.5lbs
what tire do you plan to use on a 16 inch rim on the street?
Old Mar 4, 2011 | 02:41 PM
mrboost05's Avatar
stock evo wheels are also forged alu so they will be stronger then some wheels the FD wheels are cast correct ?
Old Mar 4, 2011 | 02:42 PM
Not sure on size, but I'm running the X MR wheels that are 18 inch.
Old Mar 4, 2011 | 08:39 PM
mrboost05's Avatar
i am sure you will be fine buy whatever set you can find just check them every now and then every oil change or whatever.
Old Mar 4, 2011 | 08:44 PM
Kracka's Avatar
More sidewall flex...bad for cornering, good for straight line acceleration. The car will feel less sharp and responsive on the street for daily-driving.
Old Mar 4, 2011 | 09:57 PM
Good point kracka, thanks
poof83grt
For Sale - Wheels / Tires
Mar 8, 2016 04:24 AM
1SlowRS
Feb 6, 2016 06:46 PM
5LEEPERISAH23I
Jul 28, 2015 11:12 AM
DOUGLAS
85
May 17, 2012 03:22 PM
kanyonkid
Sep 22, 2010 01:46 PM
Quick Reply: FD wheels on the street
