rear camber eccentric bolts, how much toe?
My current rear toe is at -1, and was wondering if I flip the arrow on the rear eccentric bolt how much more negative toe will I get?
FYI, yes I did search.
I'd hope your rear toe isn't -1!
Ideally - mostly for tire wear - you want your toe close to 0 all around. Some people try to trick the car and force it to turn in AutoX with big amounts of toe-out (like up to 1/4") but it's not recommended.
I'd recommend adding camber in the front. Yes you can flip the bolt, you can and camber plates to the stock suspension too for cheap if you want even more.
CaptainSquirts
Aug 31, 2016 03:15 PM
cmspaz
16
Feb 6, 2015 10:49 AM
evozoom
20
Oct 5, 2012 01:46 AM
IzenGreyEvo7
12
Sep 10, 2003 01:58 PM
