Alignment - Rear 0 Toe or 1/16 Toe in
Going in for an alignment tomorrow and here is what Im gonna try to get. Car is bone stock.
Front Camber -2.0
Front Toe 0.0
Rear Camber -1.0
Rear Toe - 0 or 1/16 Toe in ??
Unsure what I should do about the rear toe. I read reviews and some people say 0 rear toe, and some say 1/16 Toe in for increased stability at speeds. Please advise. Im looking for more go kart type handling than tire life.
Front Camber -2.0
Front Toe 0.0
Rear Camber -1.0
Front Camber -2.0
Front Toe 0.0
Rear Camber -1.0
Front Camber -2.0
Front Toe 0.0
Rear Camber -1.0
Add a bit of toe out in the front then (+1/8 inch???). Maybe invest in camber bolts to get a solid 2.5+ degrees up front.
As for the rear toe, somewhere between 0 and 1/16 toe-in should do what you want.
Just the increase in front camber will help the car rotate much better.
alignments are setup + driver preference specific, so make sure you experiment!
idriveanevo
11
Jun 16, 2009 09:45 AM
andber
May 28, 2007 10:16 PM
Zemo
Oct 5, 2005 11:04 PM
