Alignment help
Old Apr 18, 2011, 10:28 AM
rgonyer's Avatar
Originally Posted by cfdfireman1
you are correct sir.
That's a WAY better pic... where did you find that one?
Old Apr 18, 2011, 06:19 PM
cfdfireman1's Avatar
ebay shop manual
Old Apr 19, 2011, 07:07 AM
pao
pao's Avatar
negatory - you'll be replacing tires every 6k miles with 2 degrees of cam on soft tires and daily driving it 90% of the time - get as close to zero as possible especially if you're running soft - med tires. definitely suggest you run two sets of tires (winter/summer) to get the most out of that configuration
Old Apr 19, 2011, 09:42 AM
set the camber to 0 you'll do 1 track day and have to buy new tires.
Old Apr 19, 2011, 05:55 PM
GG06MR's Avatar
You must be hard on tires and/or not rotating them often enough. I got almost 12K+ out of my stock A046's with 2 deg. neg. camber up front, and 1 deg. in the rear.
hispanicpanic
10
Mar 1, 2014 04:07 PM
runningonE
12
May 22, 2011 03:18 PM
Hiboost
13
Jun 25, 2010 03:25 PM
avo3vom
10
Jul 26, 2009 08:38 AM
Quick Reply: Alignment help
