Does anyone rebuild power steering pumps?
Old May 3, 2011 | 05:00 PM
blkmkIII's Avatar
Oem is around $800, used is $150, I saw that rock auto rebuilds them for $150, I need to call to get some more info, like where/what parts are they using. Or possibly if i can rebuild this myself. Any help would be amazing. death whine from this puppy.(ran low on fluid)
Old May 4, 2011 | 09:09 AM
blkmkIII's Avatar
yeah?
Old May 4, 2011 | 09:13 AM
prowakeskater's Avatar
Does it whine just on startups or all the time?
Old May 4, 2011 | 07:53 PM
blkmkIII's Avatar
all the time, pulled belt off, getting a good amount of movement side to side out of the pulley.
Old May 4, 2011 | 08:35 PM
FERNO's Avatar
Sounds like you may be pioneering this.
Subscribed to find out how it turns out. Good luck.
Old May 5, 2011 | 11:30 AM
blkmkIII's Avatar
HAHA, I guess so lol. I will see what the machinist side of me is willing to do about it
Old May 5, 2011 | 06:22 PM
FERNO's Avatar
Heh... I meant more along the lines of trying a rebuilt pump, but if you got the skills... GO WILD!
Is there even a rebuild kit out there?
Old May 5, 2011 | 08:03 PM
blkmkIII's Avatar
nope =(
Old May 5, 2011 | 09:28 PM
03whitegsr's Avatar
Maybe a stupid question, but have you followed the FSM procedure from bleeding the system of air?
Old May 6, 2011 | 05:12 AM
TommiM's Avatar
Have you tried flushing out the fluid and see if that does anything? there is a little bit of wiggle on the pulley when you move them. there shouldnt be a lot but there is some normally, if thats what concerning you.
Old May 6, 2011 | 04:41 PM
blkmkIII's Avatar
the whine is the concern. sounds like I have a supercharger. I didnt flush, however I did bleed it by lifting the front and doing full lock to full lock several times... nothing.
Old May 6, 2011 | 05:10 PM
FERNO's Avatar
I got the bleeding advice also, albeit on a different kind of car. If you try it for 30 minutes and it doesn't get quieter, chances are it is as quiet as it gets. Not sure what the FSM procedure is for Mitsu.
Old May 6, 2011 | 05:12 PM
ive heard that putting grease into the area where the pully meets the pump works... but from what I understand the bearings are sealed...
Old May 6, 2011 | 05:13 PM
blkmkIII's Avatar
I was getting no air bubbles even at full lock. they are probably sealed, but it is food for thought.
Old May 6, 2011 | 07:26 PM
wait, whats up with doing that full lock to lock? Im getting bad screeching on startups, mainly on warm starts
Quick Reply: Does anyone rebuild power steering pumps?
