Does this Alignment look good?
Just put on new tires (*Spec Z1 235/45/17) and went to get my alignment done.. here are the results... The Front CAMBER has me Also i'm DD the vehicle for now, no track days yet. Thanks for your time fellas.
FRONT
CASTER
Left: 3.6
Right: 3.9
CAMBER
Left: 0.3
Right: 0.2
TOE
Left: 0.00
Right: 0.00
Total: 0.00
REAR
CAMBER
Left: -0.7
Right: -0.8
TOE
Left: 0.10
Right: 0.05
Total: 0.15
FRONT
CASTER
Left: 3.6
Right: 3.9
CAMBER
Left: 0.3
Right: 0.2
TOE
Left: 0.00
Right: 0.00
Total: 0.00
REAR
CAMBER
Left: -0.7
Right: -0.8
TOE
Left: 0.10
Right: 0.05
Total: 0.15
I'm really just looking to DD for now and really not trying to have the tires wear unevenly or obscurely. Again i'm on stock tire size and stock suspension. So i should go back and look to be in -1.0 range for FRONT CAMBER? What about the rear? Thanks again guys!
The stock Evo has a camber bolt with 2 selections on it. -1 and -2. If on the -1 selection you'll be in the -1 range +/- .3. Which is why I doubt their machine was calibrated (SOP is everyday, but people are lazy).
Use the -1 bolt selection up front. Rear looks ok. Zero toe all around.
try -1.5ish up front and -1.0ish in the rear for less wear on the tires and uncompromised handling. You could also 0 out the toe all around (I do) but there are many different opinions here.
When I read the title, I thought we were going to be looking at corner balance charts!
So i took it back to NTB and they told me that was the best they could do and that i would need a "eccentric blot"to get the desired values.. I'm confused don't Evo's roll off the assembly line with -1 CAMBER? Why can't they replicate it now? Again stock tire size and rim.
TxFAkuma
Feb 17, 2017 03:45 PM
