Tire fitmment question
Old May 16, 2011, 08:36 AM
spooldursti's Avatar
Arrow Tire fitmment question
Hopefully here pretty soon I'm looking at getting the rota g-force in 18x9's. My question(s) would be if a 255/45/18 would fit without rolling the fenders on my Tanabe gf-210 springs. I havent seen that tire on combination before on my particular set-up. Or would I have to go with a 245 maybe? I dont want to run a 245 on a 9'' wheel if its gonna stretch the tire to make it look ugly. Any advice?
Dylan
Old May 16, 2011, 08:38 AM
Neal@tirerack's Avatar
That seems way taller than what should work. 27" od is really pushing it on a stock height car let along dropped. 235/40-18 or 255/35-18 best bets.
Old May 16, 2011, 08:40 AM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
255/35R18 is more standard here not 45.
Old May 16, 2011, 09:41 AM
Ludikraut's Avatar
IIRC most 265/35R18 tires are very close to the stock tire diameter - but you'd have to roll your rear fenders to get them to fit. A 255 width tire should fit w/out rolling but will be slightly smaller in a /35 and slightly taller in a /40. If you have a specific tire in mind, go to the tire specs page on tirerack.com and see how they measure up to the stock diameter, which is 25.3".
l8r)
Old May 16, 2011, 09:46 AM
Would a 255/40 work? I think a 35 would be too small of a sidewall. we dont have the best streets here in Topeka. I need a little "flex" room for comfort.
Old May 16, 2011, 09:57 AM
Smike's Avatar
Sidewall is a ratio to tread width. 235 *0.45 = 105.75mm (4.2in).
235/45R17 - 4.2in and OEM size
255/35R18 - 3.5in sidewall and 1.2% shorter diameter
255/40R18 - 4.0in and 2.6% taller
265/35R18 - 3.7in and 0.2% shorter
Look at weight per package too. You're looking at adding a significant amount of rotational mass. Thats going to hurt performance and feel of the car.
Old May 16, 2011, 10:24 AM
Ludikraut's Avatar
A /40 series will be about .5 to .7" taller. I'd search the forums to see if anyone is running that size.
l8r)
Old May 16, 2011, 11:23 AM
Is it really going to be that noticeable? As in making my car "slower?" Because I definitely don't want that.
Old May 16, 2011, 11:58 AM
Smike's Avatar
Yes.
Old May 16, 2011, 12:11 PM
Ludikraut's Avatar
Unless you're competing in Auto-x or other forms of racing, it's not that big of a deal. For a street driven car I wouldn't worry about it.
l8r)
Old May 16, 2011, 12:15 PM
Smike's Avatar
We disagree. It comes down to physics. Takes more power to move that wheel package. Will slow down turning response. And take longer to brake.
Old May 16, 2011, 12:25 PM
Ludikraut's Avatar
I don't disagree that there is a benefit to reducing unsprung weight, but it's so easy to make power with the Evo that it wouldn't be very high on my list of mods unless I'm competing in a classed event where I have to adhere to restrictions.
Now maybe if I was driving a Focus ... erm ... cough... Hah!
j/k man.
Personally, if I was the OP, I'd get the rear fenders rolled and run 265/35s ... Not only do I recommend this solution, I also run it on my car. ...now where'd that bottle of rogaine go?
l8r)
Old May 16, 2011, 12:37 PM
Smike's Avatar
Racing a Focus...she lives and dies by what weight I can cut
Weight savings works (or hurts) any car. I prefer the lighter options. Quicker everything. Win for me.
Old May 16, 2011, 01:45 PM
Thank you guys for the quick response's. So we've established that a 255/40/18 WILL work with no rolling but not "recommended" for weight purposes, rotational mass etc.. And a 265/35/18 is recommended with rolling the rears and in all purposes "better" than the 255/40?
Old May 16, 2011, 02:05 PM
Ludikraut's Avatar
My main reason for choosing a 265/35R18 was because it was exactly the same diameter as stock. Secondary reasons were that I like the look of a wider tire and with the lower aspect ratio, you normally get a slightly stiffer sidewall (when compared to the same tire with a taller sidewall).
So far though, you haven't talked about the most important thing - what tire are you getting? Many tires will only be available in one size or the other.
l8r)
Quick Reply: Tire fitmment question
