What tires fit 18x9.5 wheels?
I have a set of toyo proxies4 215x35x18 that have been offered to make up for a bad deal w/ bent wheels.
Will they fit a 18x9.5 +20 wheel? Or should I not even bother?
I have a 235/40/18 on a 18x9.5 and that is the most stretch I am comfortable with, but it depends on the tire, some run wider than others in the same size. I'm using Hankook Evo V12's and the rim width range is 8.0-9.5 so check the manufacturer specs on each tire you are considering. I wouldn't go lower than a 235 since that is the stock tire width.
Tirerack aslo isn't allowed to stretch tires. That is a company policy. That is prob why they don't "rec" anything smaller than a 245 because anything smaller they won't put on. I know a few people with 215s and 225s on 9.5.
Personally my Grids are going to have 245s becuase I have brand new 245s I need to use up. After that they will get 275 or 285s.
Mikey
Mikey
