Alignment recommendation
Hello all,
I'm looking for alignment spec suggestions.
DD with around 4-5 HPDE days per year.
05 VIII
Stock KYB's with Robispec springs
245/40/17 Star spec's
Master Bushing kit
Whiteline Bumpsteer and RCK.
thanks
05 VIII
Master Bushing kit
thanks
Easy enough..
Front: set eccentric/camber bolt for the most negative camber up front approx -2.x*, run zero toe.
Rear: Set camber about -1.0*, again zero toe.
Perhaps look into sway bars front & rear as well, or at least rear bar, and modify the front bar to increase stiffness.
Roen
12
Aug 15, 2013 08:33 PM
PaRanHaNeul
16
Nov 7, 2008 05:08 PM
BIGWING
Sep 9, 2003 08:05 AM
