17x9 wheels that are still alive and are under $1,000 in 2011
Old Jun 18, 2011, 10:28 AM
  #31
FJF
FJF's Avatar
Originally Posted by Craig King
See, I disagree about the 18s being cheaper. Sure, you might be able to pick up just the X wheels for a little cheaper than NEW 17x8.5 RPF1s, but the cost of tires for 18s is going to be more expensive in the long run. I would rather retain the 17" diameter where tires are not as expensive.
Agreed. Plus, the weight. 17x8.5 RPF1s are ~16lbs vs EvoX 18s at ~22lbs. That's ~6lbs per corner and for what?
Old Jun 18, 2011, 02:18 PM
  #32
sparky's Avatar
Originally Posted by heel2toe
.....I ended up buying 17x9.5 +38 NT03's.... I was able to fit a 9.5 inch wheel with no spacers and apparently no fender rolling with up to a 255 tire....
So, if I understand this correctly, I can run 17x9.5"+38 NTO3 mounted with a 255 tire and it will not rub the fenders or my Bilstein struts/springs? Thanks, I just wanted to make double sure before ordering.
Old Jun 18, 2011, 03:00 PM
  #33
killerpenguin21's Avatar
how much of a spacer do the 17x9.5 rpf1's need in front?
Old Jun 18, 2011, 06:18 PM
  #34
Evolutionn's Avatar
^depends on the offset you use... search +18 requires no spacers but they look like crap, sticks way the hell out the front fenders.( friend has them)
Old Jun 18, 2011, 07:18 PM
  #35
evobjcj's Avatar
thanks this is good info to know about the 17x9 rims.
Old Jun 18, 2011, 08:32 PM
  #36
Boltz.'s Avatar
If you want cheap and light go with the 17x9.5 RPF1 (+18f/+38R). No spacers and a lot lighter than the NT03's.
Also will handle better than the NT03's because of the wider track up front
Old Jun 18, 2011, 08:42 PM
  #37
will the 17x9.5 +38's work with a 15mm up front to widen the track?
Old Jun 18, 2011, 08:50 PM
  #38
novem's Avatar
Buddyclub 17x9 ..no spacers..no fender crap..3 colors and there is a vender on here that sells them.
N
Old Jun 19, 2011, 06:10 AM
  #39
theEVOdream's Avatar
+38 offset requires a 20mm spacer +18 offset requires none.
Old Jun 19, 2011, 07:30 AM
  #40
Craig King's Avatar
N
Link?
Old Jun 22, 2011, 03:04 AM
  #41
novem's Avatar
https://www.evolutionm.net/forums/ev...ffordable.html
N
Old Jun 24, 2011, 10:46 PM
  #42
CrunchyMilk's Avatar
I'm really surprised I don't see more Team Dynamics 1.2's. For $224 a wheel and a proven race history they are a top contender in my book.
Old Jun 26, 2011, 08:35 PM
  #43
evo3gsx's Avatar
Good call. There was talk about an 18x10 being released but they don't have any info on Team Dynamics website. At any rate, the 17x9 looks awesome and comes in Evo offsets.
Some pics: https://www.evolutionm.net/forums/ev...-400-rims.html
Old Jun 27, 2011, 04:45 AM
  #44
FJF
FJF's Avatar
If you notice, the OP cites Team Dynamics in the original post.
Old Jun 27, 2011, 03:40 PM
  #45
heel2toe's Avatar
Sorry I havent looked at this thread in a while. Anyway, I cannot comment on the lack of rubbing with a 255 tire however I can tell you that the actual rims do not rub on the struts nor do they require the use of spacers. Currently I am running Bilsteins with Robispec springs on 245 star specs and have no fitment issues whatsoever.
I will try and snap some photos of my car this week which will atleast give you an idea what the 17's look like.
Quick Reply: 17x9 wheels that are still alive and are under $1,000 in 2011
